#51 |
Re: wierd cooling system problem noise ?
Whatever works, I'm glad you got right. Your way should be really good for an AC truck with the cut-off valve in the line. Here is a picture of mine before I installed a new heater core and plumbed it in. It's still the same except now the water runs through the heater core and back to the pump.
#52 |
I got the same setup as k30. Vortec heads and serpentine drive. I never had any problems. This thread made me think so I did some investigating. The ONLY time I don't have flow thru the block/pump is when the thermostat is CLOSED AND the A/C is ON! That's because I have Vintage Air and it uses a heater block off valve that closes of the heater core when the AC is on. For that one rare occasion, I went ahead and installed a bypass hose (see pic). Kept it simple-less than $5 in parts. Problem solved.
#53 |
sun soaked . . . same rpm intake and arp bolts no less and temp sender in the bypass port .
![]() i guess i am the unlucky guy the first 2 didnt work good and it needed the bypass port direct to the intake .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#54 | |
#55 |
Moderator
![]() ![]() Join Date: Aug 2011
Check out this bypass pic from a 65 with a V8 board member cru_zn_29 owns:
#56 |
nice pic .
i got my 90* and 45* barb fittings the other day . when my new intake shows up and gets installed i will post a few pics of the cleaner install and new intake setup i picked to feed the truck . ![]()
#57 |
Moderator
That engine is a 1965 model 327 (or 283?), using a bypass? Old style heads? Hello?
#58 |
60-66 Nut
That factory bypass was used on mostly medium duty trucks back in the day but some light duty trucks came with them also.
#59 |
Moderator
Good info. That's something I never realized, so it's not new for small blocks. Interesting.
I looked at 5 different 60's small block cast steel intakes on eBay they all have the bypass nipple attached. I never noticed that before.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 02-01-2019 at 08:23 AM. |
#60 |
60-66 Nut
The factory small block thermostat bypass you posted a pic of, actually uses a piece that installs under the thermostat housing which the bypass hoses attaches to, What you were seeing on those 5 cast iron intakes is likely the heater hose nipple.
#61 |
Moderator
Good info there, thank you,
#62 |
60-66 Nut
Post #3 in this thread shows what I am talking about.
http://www.67-72chevytrucks.com/vboa...d.php?t=780199
#63 |
I am losing my MIND trying to read and learn all of this. So far Google has me deep down a rabbit hole haha. So, I think I can run a regular reverse flow long pump (Like from a TPI 3rd Gen camaro) and just run a nipple in the top of the water pump to the 3/8 NPT water bypass in the front of the Edelbrock Vortec intake that I have?
My mother is a recent cancer survivor and this truck build is for her |
#64 |
That's it.
