Old 02-01-2019, 07:53 AM   #1
72velle
72velle's Avatar
84 gas gague problem
Hello folks,
trying to figure out whats wrong with the gas gague. When it works it is accurate. When it doesn't work it stays on E. It isn't consistent but mostly stays on E.
Any Ideas?
TIA!
72velle is offline   Reply With Quote
Old 02-01-2019, 09:02 AM   #2
mongocanfly
mongocanfly's Avatar
Re: 84 gas gague problem
Sounds like loose/bad wiring or bad ground...
https://www.fillingstation.com/artic...ugetesting.htm
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-01-2019, 11:12 AM   #3
Dead Parrot
Just remember our trucks are 0-90 ohm. Says something about the original design that it survived into the 90s with minimal changes.
Dead Parrot is offline   Reply With Quote
Old 02-01-2019, 01:17 PM   #4
Bandit130
Bandit130's Avatar
One thing you can try is to remove bezel, lens, light reflector, screws from gauge, clean the three prongs on back of gauge with sandpaper and then use something like alcohol. I used a slot screwdriver with sandpaper over the tip and cleaned the three clips inside, then cleaned with alcohol. Made a little difference for me, but at least they are making better contact now. The clips get rusty over the years. You may want to do all gauges that have clips.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 02-02-2019, 08:11 AM   #5
Normally I have found that if it is a grounding issue the guage will swing way past fuel, normally about 3 0clock position. Normally if it is on E, then there is a lack of 12V to the sender. Since it seems irratic by your description, I would check for a loose connection or broken wire to the tank sensor.
Old 02-05-2019, 08:36 PM   #6
72velle
72velle's Avatar
Thanks folks, I will let you know what I find.
Old 02-06-2019, 02:10 AM   #7
hatzie
Moderator
hatzie's Avatar
This is not a bad or loose sender ground.
The fuel sender is a variable resistance to ground from 0-90Ω. The fuel sender does not get power it's a passive component.
0Ω resistance through the sender makes the gauge read Empty on the gauge and 0Ω on the sender wire is a dead short to ground.
The needle randomly swinging to E means the sender wire is chafed or pinched and intermittently grounding out to the body or frame somewhere along its' run between the sender and the fuel gauge itself.
In contrast 90Ω is Full and more resistance than that drives the needle toward the 3:00 position. A completely open connection is higher resistance than 90Ω.
This is not a loose sender connection. Loose, corroded, and completely open connections cause the needle sweep to shift toward the 3:00 position. A corroded sender clip in the cluster could make the gauge read 1/8 when the tank is stone empty but it would not drive the needle toward the E position.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
