Old 02-06-2019, 03:34 PM   #1
EPS3
72 control arms vs 73
I'm considering using a front steering Chevy C10 cross member (or at least control arms) on my 1937 Buick Hot Rod.
From what I have read, the biggest difference from 72 to 73 control arms is the switch to rubber bushings.
72 control arms are less expensive, but would I be better off with 73 control arms?
EPS3 is offline   Reply With Quote
Old 02-06-2019, 10:49 PM   #2
Mike C
Mike C's Avatar
Re: 72 control arms vs 73
Personally, I think the truck front end is too wide for a 30's car. You would be much better served with a Camaro or Nova subframe or an A body donor such as a Chevelle. Or even an S10 for that matter. And any of those tap you into the 4 3/4" bolt circle wheels which there are more choices.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-07-2019, 09:12 AM   #3
jbarron
Why not just get a mustang II kit for it?
Probably look cleaner and the rack and pinon steering is easier to deal with.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 02-07-2019, 11:37 AM   #4
EPS3
Thanks for the feedback. I'm still weighing the options. If I use a C10 cross member then I will have to narrow it. Have considered the Camaro sub frames but the 37 Buick uses the rails of chassis to locate the front fenders. The 37 rails are 32.5" wide in at firewall and 26.5" wide at the axle. The control arms are also angled rearwards (See picture). The Camaro sub frame has been used successfully for models a couple of years later but I have not seen or heard of a clean install for my year car. I also already have 5 on 5 wheels purchased for this project.
Do you think 72 C10 control arms would be 73 better and why?
Old 02-07-2019, 11:54 AM   #5
EPS3
Thanks for the feedback. A Mustang II front suspension is possible but the car already has IFS with spring pockets so would require cutting off those pockets.
I would like to adapt and keep those pockets if possible
I got a killer deal on a RetroRack (Australian company) to adapt rack and pinion.
Old 02-07-2019, 12:20 PM   #6
vics stuff
Stick with a mustang II suspension set up. You will be glad you did.
Vic
vics stuff is offline   Reply With Quote
Old 02-07-2019, 12:54 PM   #7
EPS3
Is there anyone here who will share opinion on my original question?
Old 02-07-2019, 04:06 PM   #8
Barnfind46
Barnfind46's Avatar
I converted my '68 to later model front suspension to get disc brakes and have run the older control arms on other trucks. I have been happy with both. As long as all parts are in good condition they both work just as well. If you are concerned about deflection on the rubber bushings you can always go with urethane.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 02-07-2019, 04:21 PM   #9
EPS3
Thanks very much for the information.
Do the older style arms need to be greased more often?
Do the arms with rubber bushings provide a smoother or less jarring ride?
Old 02-09-2019, 01:08 PM   #10
Madkidd007
Madkidd007's Avatar
As long as you’re not trying to interchange a 1 ton arm with the bolt on setup they will swap out. Lowers I believe the bolt holding the shaft onto the crossmember got larger in diameter. Uppers are a direct bolt on. As far as greasing goes it’s no different than any other metal on metal wear item. Grease items when doing usual maintence and it shouldn’t matter.
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 02-11-2019, 11:37 AM   #11
EPS3
Thanks for this information.
