#3026 |
Re: PO has me PO'd
#3027 |
Re: PO has me PO'd
I decided to carry my stud idea a little further, I screwed up one of the studs by not using the correct tool, thinking a torx would work, but not
#3028 |
Re: PO has me PO'd
#3029 |
Re: PO has me PO'd
decided to wax the brackets, I like the look of semi rust, but wanted to protect them some what
whiskey :30 ![]() all phillips heads replaced with square drive, hated that little burr you get with phillips head, even with a new screw driver and correct head ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-08-2019 at 07:22 PM. |
#3030 |
Re: PO has me PO'd
decided to take it a step further, tracks haven't been lubed since who knows when....
and dum dum never ![]() ![]() don't know what WTR stands for , but I grabbed it when I had first honors, to go thru my brother in laws garage. He worked for boeing-vertol right after his service in the Marine Corps
#3031 |
Re: PO has me PO'd
working on adapter for trans. temp. sender
![]() ![]() easy peezy ![]()
#3032 |
Re: PO has me PO'd
#3033 |
Re: PO has me PO'd
What did you dum dum on the tracks?
#3034 |
Re: PO has me PO'd
underneath the mounting brackets, where it mounts to the floor, it squeezed out, About a 1/4" roll all the way around, plus the bolt hole
#3035 |
Re: PO has me PO'd
Oh, okay. That makes sense
#3036 |
Re: PO has me PO'd
a little trouble with the back bracket for the Lokar shifter. Have to buy a 5/8" spacer and a 3/8"-16 X 3" bolt
#3037 |
Re: PO has me PO'd
finished up rear trans mount, ordered 3" bolts had to cut down to 2 1/4"
![]() working on shift lever, changing 1/4" hole to 5/16" for studded rod end
#3038 |
Re: PO has me PO'd
Threaded 5/16" rod and studded rod end came today, working on shifter linkage
![]() also picked up my Nic cop brake tubing from NAPA 5/16" ![]()
#3039 |
Re: PO has me PO'd
finished mod to 5/16" studded rod ends for Lokar shifter
![]() now onto vacuum line for trans
#3040 |
Re: PO has me PO'd
Looking good Jim. Stud idea on seat mounting is great. Makes installing carpeting a lot easier if you are going that route.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#3041 | |
Re: PO has me PO'd
Your truck is looking great, my shop is 14 by 18 but it is heated, so I can spend my time in a t shirt My son offered to help finish my truck in april march, so it will be headed your way
#3042 |
Re: PO has me PO'd
#3043 |
Re: PO has me PO'd
#3044 |
Re: PO has me PO'd
Ya made me chuckle, looking at end of summer, when all those wires terminate at a senser or something
#3045 |
Re: PO has me PO'd
I find it hard to believe you haven't made any new progress. What's up?
#3046 |
Re: PO has me PO'd
sorry for not updating, but just enjoying life. this is my off season, where I catch up on my other projects. Did get to drive the shifter cart for a while, it's a blast.
doing alot of road trips, just got back from Sturbridge flea market, lots of cool stuff up there, picked up some automobilea.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-18-2019 at 07:36 AM. |
#3047 |
Too Dumb To Know Better
Re: PO has me PO'd
That's not a good excuse Jim. Those of us without skills need our regular dose of progress.
J/K. Enjoy your off season. |
#3048 |
Re: PO has me PO'd
alright,alright! I got you're drift, no more crickets. Here are some updates, quadrajet and dual point dizzy going back in, TPI and computers going on the shelf. Pics to follow
#3049 |
Re: PO has me PO'd
#3050 |
Re: PO has me PO'd
That looks nasty.
