Old 02-07-2019, 11:32 AM   #1
ChadW
Header selection....
Need a set of headers for a sbc 327 with aluminium Trick Flow Twisted Wedge (angle plug) heads...going on a lowered/bagged 66 c10 so will probably need to be block huggers or a short header of some type that will keep the exhaust above the bottom of the frame rails. Thoughts, opinions etc?? Id like to find a midlength "clipster" header that will work.. something like these possibly?
https://www.ebay.com/itm/RACING-PERF...frcectupt=true
ChadW is offline   Reply With Quote
Old 02-07-2019, 11:45 AM   #2
LVPhotos
LVPhotos's Avatar
Re: Header selection....
If not manual, or use a hydraulic clutch bearing...
HOOKER 2466
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-07-2019, 11:50 AM   #3
ChadW
HOOKER 2466
Not manual...will be a 700r4..those are an option...would about any that are for a 67-81 camaro fit?
Old 02-07-2019, 12:00 PM   #4
LVPhotos
LVPhotos's Avatar
This is another 62 with bars. I would check faq section... but sounds right. Or 67-72 truck
Old 02-07-2019, 12:02 PM   #5
LVPhotos
LVPhotos's Avatar
My 62
Old 02-08-2019, 01:23 AM   #6
Captainfab
60-66 Nut
Trying to find a combination of a shorty or mid length header that will also work with angle plug heads is going to be a challenge. I can say from experience that the Hedman 69260 headers that are made for these trucks will work with angle plug heads. But they do hang a little below the bottom of the frame. Since you are going with an auto trans (I assume you are removing the bellhousing crossmember) then you can use a set of 1st Gen Camaro or early Chevelle headers that are designed to work with angle plug heads. The car long tube headers do not drop down as far as truck headers. But any of those that will work, are going to be way more than the $100 ebay made in China headers.
Old 02-08-2019, 01:35 AM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
Wouldn't 69230's work?
Old 02-08-2019, 01:48 AM   #8
Captainfab
60-66 Nut
Yes, I forgot about those. I have read that they do work with angle plug heads despite what the installation notes say. And they don't hang down too low. Of course the bellhousing crossmember must be removed.
Old 02-08-2019, 12:12 PM   #9
ChadW
Thanks...I think i am leaning towards the Hooker 2466, midlength..I beleive they are ok with angle plugs as well..
