Old 02-09-2019, 02:11 PM   #1
dmccay0878
Ls swap with 6.0 from Chevy express?
Looks like the cheapest way to get an ls and trans for a swap in my area is to buy a used Chevy express van with 6.0. I have been looking around and see no reason not to buy one. Anything wrong with the van motor and trans setup?
dmccay0878 is offline   Reply With Quote
Old 02-09-2019, 03:01 PM   #2
bigmoe
bigmoe's Avatar
Re: Ls swap with 6.0 from Chevy express?
If you reuse the vans wiring harness they are longer which is a bonus for locating the PCM somewhere like in the cab under the seat. Other than that the combo should work fine. Probably need to replace the dipsticks which will be pretty long.
bigmoe is offline   Reply With Quote
Old 02-09-2019, 06:14 PM   #3
kipps
Originally Posted by bigmoe View Post
...Probably need to replace the dipsticks which will be pretty long.
You'll probably be replacing dipsticks anyway. The dipstick is distinctly unhandy when removing/replacing manifolds and when pulling/setting the engine. In my limited experience, the dipstick doesn't come out of the block in usable condition. It's been crushed and mutilated from the vice grip and hammer used in pulling it.
kipps is offline   Reply With Quote
Old 02-09-2019, 11:16 PM   #4
77c10bowtie
77c10bowtie's Avatar
Are there any differences in the truck and van 4l80e
77c10bowtie is offline   Reply With Quote
Old 02-09-2019, 11:24 PM   #5
ls1nova71
ls1nova71's Avatar
No.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-10-2019, 09:42 AM   #6
jrusher
I used a ly6 out of a 2008 savanna van , harness worked great. I freshened up engine and tranny as was high miles. Added a cam and ls3 intake, stall convertor engine rips good
jrusher is offline   Reply With Quote
Old 02-12-2019, 06:25 PM   #7
04ls1gto
What cam and converter did you use?
04ls1gto is offline   Reply With Quote
Old 02-12-2019, 07:17 PM   #8
dmccay0878
I just bought a 03 Chevy express with lq4. Seems like a pretty straightforward swap. The only thing I didn’t consider is that my frame is z’ed in the front which may give me problems fitting the trans
Old 02-12-2019, 08:26 PM   #9
04ls1gto
Probably have to use a high hump trans cover or make your own
Old 02-12-2019, 08:32 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Trans dipstick is ~5" longer to clear the point where it would tuck under the cowl in the van.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-12-2019, 08:48 PM   #11
dmccay0878
I’m hoping that was already done to fit the th400 that is in there now.
Old 02-12-2019, 09:19 PM   #12
jrusher
Texas speed stage 2 vvt cam , springs and push rods too match. 2500 stall
