![]() Join Date: Jul 2018
Coolant hoses thumping heartbeat noise
I looked around some but did not see this mentioned so sorry if it’s been covered. My 71 K10 with heater no ac has a thumping noise like a heartbeat. You can feel the pulse of the coolant making the noise in the hoses to and from the heater core. You can hear it in the cab and sometimes it’s louder than others. Anyone know why it’s so noticeable or anyone have this occurring or fix this issue before?
Re: Coolant hoses thumping heartbeat noise
Is it possible that your lower radiator hose is collapsing, letting go, and re-collapsing?
OR, could it be a head gasket that has given away allowing the combustion gasses to surge into the coolant system? OR, a surging thermostat? OR , a failing water pump? I've never witnessed "heart beat" in the coolant lines...very interesting.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
Maybe your water jacket has air in it. I would check the water level in the radiator to verify it isn't low.
1981 C-10 Longbed, 250 (4.1) 2bbl Varajet, THM-350C. Some of the Build progress: https://www.youtube.com/channel/UC_W...foLyeDq_WQPNmA 1981 Harley Davidson. Credentialed, semi-retired A.S.E. technician. If you don't like free advice, Ask Someone Else and pay for it. |
![]() Join Date: Nov 2018
Pull the thermostat and drive it to see if it goes away. Simple, quick and easy to do.
A stuck or malfunctioning thermostat will cause a hammering problem like you describe. |
I'm not much of an expert on anything, but I don't recall ever seeing heater hoses routed like the ones on this engine. Usually one hose goes from the water pump to the heater core and one hose goes from the intake manifold to the heater core. Never seen a heater hose that goes to the radiator. Also never seen a radiator that has a heater hose outlet or inlet. What that might have to do with the symptoms being experienced I can't say but...?
#6 | |
Thanks guys! It works great, heats the truck well and keeps the engine cool so I’m probably just being nit picky.
#9 | |
Looks like you have a quick release lever type cap. They’ll make your coolant system do that. As for hose and flow routing, intake to bottom of core, top of core back to water pump or to the rad if your system is heavy duty. |
sub'd
I didn't want to respond too quickly but I replaced the radiator cap and the thermostat (OE spec style same as before) and it does seem to have subsided. It was not causing any sort of issue before and I have been listening for it everytime I drive and its my daily driver so I think between those 2 things its good. If it happens again I will let ya know.
