02-14-2019, 12:41 AM | #1 |
Some parts FREE! 1972 Blazer Parts, Inner/Outer Heater Box, MORE!
Still have a few items here...a grille, 4X4 front hub, steel lines, and some wiring. All parts (except brake back plate) are original and came off my 1972 K5 from South Dakota. Asking prices below plus shipping from 22191. I can provide additional photos.
SOLD! Bucket Seats & Brackets (driver slider, passenger tilt, seat cushions and upholstery bad, brackets and seat frames good) SOLD! Gas Tank Skid Plate SOLD! 21-Gallon Gas Tank $50 SOLD! Inner Heater Box; SOLD! Outer Heater Box; SOLD! Heater Control w/Cables; SOLD! Radiator (no leaks) $40: Grille & Chrome Shell (cut in bottom center for winch clearance - see photos); $30: Steel Fuel Lines; Wiring (includes voltage regulator, ignition switch, fuse block, front grlle turn signals); Wheel Hub (Dana 44) $10: Long Front to Rear Brake Line; SOLD! Door Mirrors SOLD! Disc Brake Backing Plate (see photos, ordered as a replacement but didn't match my K5...maybe from a 2wd?); SOLD! Blower Motor w/Wheel; FREE: DONATED! Brake Master Cylinder DONATED! Brake Vacuum Booster DONATED! Brake Prop Valve DONATED! Heater Core (no leaks) DONATED! Speedometer Cable DONATED! Headlight Switch w/Knob
Rob "1967 Wanna Be" 1972 K5 Blazer Last edited by Another 72; 02-21-2019 at 05:00 PM. |
02-14-2019, 02:29 AM | #2 |
Carpe manana
Re: Some parts FREE! 1972 Blazer Parts, Inner/Outer Heater Box, MORE!
Rob -
From the free pile I'll take the speedo cable, headlight switch w knob, and the prop valve: let me know cost to ship to 54701. If the mirrors are in good shape with part #'s on them I'd take those also - do you have the backing plates for them by chance? Any OEM nuts, bolts, screws from the Blazer you aren't going to reuse? Thanks, Pete
02-14-2019, 02:46 AM | #3 |
Collector of Projects
I would be interested in the door mirrors.
Are they GM or Reproduction? Any better pictures of their condition? |
02-14-2019, 07:25 AM | #4 |
I will Take the radiator, heater control and heater core shipped to Pa 17517 picture of inside of outer heater box?
02-14-2019, 08:02 AM | #5 |
I will take the passenger side door mirror. Message sent, thanks!!!
02-14-2019, 02:39 PM | #6 |
Additional mirror photos attached. Fairly certain these are clean OEM mirrors. Reflective surfaces on LH and RH are pretty much perfect. Chrome is very good with exception of visible blemishes on underside of both bases, especially on RH. Mirror adjustment is very tight like new. Easily worth what I'm asking.
Rob "1967 Wanna Be" 1972 K5 Blazer Last edited by Another 72; 02-14-2019 at 02:49 PM. |
02-14-2019, 02:47 PM | #7 | |
02-14-2019, 02:54 PM | #8 |
Thanks, just googled it. Looks like the part numbers on my mirrors match part numbers on LMC repro mirros which LMC sells for $40 each (vs. $10 each). What numbers would be on OEM mirrors?
Rob "1967 Wanna Be" 1972 K5 Blazer |
02-14-2019, 02:57 PM | #9 |
02-14-2019, 03:12 PM | #10 | |
Rob "1967 Wanna Be" 1972 K5 Blazer Last edited by Another 72; 02-14-2019 at 03:18 PM. |
02-14-2019, 03:16 PM | #11 |
Outer heater box photos attached - would you like it too?
02-14-2019, 03:47 PM | #12 |
$150 shipped for radiator, heater core, and heater control with cables. $250 shipped for radiator, heater core, heater control with cables, and outer heater box (requires deeper box).
02-14-2019, 03:56 PM | #13 |
Carpe manana
Thank you - I’ll take the pieces less the mirrors. Thanks for the extra photos. PayPal ok? If you happen to have any spare oem nuts bolts clamps etc. you won’t be using please toss ‘em in the box. Pete
02-14-2019, 04:41 PM | #14 |
PM sent!
02-14-2019, 06:00 PM | #15 |
I'll take the mirrors if they get to me. PM shipping to 98042 please.
02-14-2019, 06:50 PM | #16 |
02-14-2019, 09:37 PM | #17 |
it is 4 cores
02-14-2019, 09:44 PM | #18 |
I meant to type earlier that I would take both mirrors not just the passenger. Not sure why it only showed part of my message. I will take both mirrors, message sent.
02-14-2019, 09:58 PM | #19 |
PM sent
02-14-2019, 11:35 PM | #20 |
Carpe manana
Payment sent. Thanks. Pete
02-15-2019, 10:49 AM | #21 |
I will pass on the heater box. I take the radiator, heater core and the heater controls + cables Thanks
02-15-2019, 11:10 PM | #22 |
PM sent.
02-16-2019, 09:55 AM | #23 |
Tank arriveSD nicely packed! Thank You!
