Old 02-19-2019, 04:33 PM   #1
dondb
any secrets to removing a arm shaft bolts
Have my upper and lower a arms out for a front suspension rebuild. Everything is out and a part, except I can't get the lower a arm shaft bolts out. I have a 2 foot 1/2" breaker bar with the shaft in a vice....and the breaker bar bends to a uncomfortable amount. I had to get a 1 5/8" 3/4" socket with a 3/4 to 1/2 reducer. That alone set me back 30 bucks! Maybe a cheater bar???? Probably snap the 1/2" breaker bar?
1969 C-10 LWB SS
1969 Camaro Pro Tour
2002 Camaro SS LE Rag Top #937
dondb is offline   Reply With Quote
Old 02-19-2019, 05:14 PM   #2
weq92f
weq92f's Avatar
Re: any secrets to removing a arm shaft bolts
Dang! Righty Tighty.... LOL jk
Use some penetrating oil and an impact. Mine came loose using a large pipe wrench and a BFH.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-19-2019, 07:00 PM   #3
dondb
LOL.....Thanks for those instructions...I will not forget them:
Got them off.....found my 22 year old son and a cheater bar off my jack handle. Still almost pulled my vise out of the bench
1969 C-10 LWB SS
Old 02-19-2019, 07:04 PM   #4
bmxbang
Ha ha, I know the pain! Glad you got them out when I did mine I ended up bolting them back on with the U bolts on to the truck and getting them loose that way.
bmxbang is offline   Reply With Quote
Old 02-19-2019, 07:07 PM   #5
68 P.O.S.
While you have it torn apart, upgrade to the 9/16" lower control arm u-bolts for safety. The original ones liked to snap when reversing with the wheel cranked all the way in either direction. Dorman 13503 are the ones you want. Other vendors have them as well.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 02-20-2019, 09:40 AM   #6
bean
Doing dame thing to my 72. Wound up cutting old bolts off and as previously mentioned upgraded to the 9/16 . summit has them for 12$.
bean is offline   Reply With Quote
Old 02-20-2019, 10:23 AM   #7
dondb
What are the torque specs for the upper and lower a arm shafts? I have seen different numbers for new vs original?
1969 C-10 LWB SS
Old 02-20-2019, 10:24 AM   #8
Grumpy old man
Grumpy old man's Avatar
The secret is to loosen them BEFORE you take them off the frame , Once you have the ball joints loose and remove the spring use the weight of the frame to your advantage and loosen the shaft bushings . I used a 20" Cresent wrench and a cheater bar to remove the shaft bushings ,Then once they are loose enough that you don't have to wrestle with them in a vice remove the A arms from the frame . Easy Peasy , When installing them mount the new shafts to the frame first and locate the pin and torque the lower new 9/16 Ubolts , the upper shaft can just be slid into place and then install the A arms and the new bushing caps again using the frame instead of assembling them with a bench vice . I used all new Moog parts and cleaned /primed and painted so the last thing I wanted to do was clamp them in a bench vice . It was easy and fast and no scratches or marred up parts . once assembled use some Dykem torque seal to mark the installed position and it gives you a good quick check to make sure they haven't moved / loosened up on you
https://www.youtube.com/watch?v=h5fXwNzPEso
https://www.aircraftspruce.com/catal...iABEgIOwPD_BwE
( Orielly's $9.49 for the Dorman 13503)
Old 02-20-2019, 10:33 AM   #9
72ironmike
72ironmike's Avatar
Good luck with this question ! Finding the correct torque is tough. Service manual is misprinted. New vs original makes sense since the original would already be splayed out in the a arm collar. Using the original a arm may accept less torque ? I called the "Moog Experts" & they were about as much help as a wet paper bag. "Gee I dunno" they said. One friend suggested torqueing till still movable and tacking the heads so they don't back out ? Is it half ton or three quarter ? A1Auto sells 3/4 pairs with ball joint for about $100 pre torqued. Again, Good Luck.
72ironmike is offline   Reply With Quote
Old 02-20-2019, 10:35 AM   #10
72ironmike
72ironmike's Avatar
"once assembled use some Dykem torque seal to mark the installed position and it gives you a good quick check to make sure they haven't moved / loosened up on you"
Great advice ! Thanks Grumps.
Old 02-20-2019, 10:46 AM   #11
dondb
Thanks for the heads up on finding correct torque specs!
And Thanks for the installation procedure to the arms Grumpy...I noticed in your pics your lower a arm has what looks like a sway bar bushing? Asking because my 69 1/2 ton does not??
1969 C-10 LWB SS
Old 02-20-2019, 11:00 AM   #12
Grumpy old man
Factory sway bar , they are 1 1/16" and later 1 1/4" the mounting holes are already in your factory A arms and frame . You can find them on the parts board . The frame brackets are available aftermarket for stock stance and they make a set of brackets for a lowered truck using a factory sway bar also . I used Energy suspension bushing on this truck build .
Old 02-20-2019, 11:13 AM   #13
dondb
Thanks for the explanation I see the 2 holes for the bushing in my lowers...I bought a 1 1/4" from CPP and they mount differently then yours. Wish I would of known this particular way before i bought mine.I like your set up more.
1969 C-10 LWB SS
Old 02-20-2019, 11:15 AM   #14
Grumpy old man
These are the specs I use . I always use the Dykem just to be sure on suspension/ steering .
Old 02-20-2019, 11:18 AM   #15
72ironmike
72ironmike's Avatar
Grumpy, Where does it show the steel bushing C10 torques ?
Old 02-20-2019, 11:32 AM   #16
Grumpy old man
I found these in another thread from the factory manual
http://67-72chevytrucks.com/vboard/s...d.php?t=471554
Old 02-20-2019, 11:33 AM   #17
dondb
I believe the specs supplied above states 115 ft-lbs for a arm bushing bolts.
1969 C-10 LWB SS
Old 02-20-2019, 11:45 AM   #18
dondb
[QUOTE=dondb;8470388]I believe the specs supplied above states 115 ft-lbs for a arm bushing bolts.[/QUOTE
Grumps....you snuck in another spec sheet in there before my post...so 115 is for previous sheet. Also i believe the one above should say upper control arm bushing, instead of 2 lowers?
1969 C-10 LWB SS
Old 02-20-2019, 11:59 AM   #19
Wrenchbender Ret
Do the holes have to be drilled out for the larger u-bolts?
George
Wrenchbender Ret is offline   Reply With Quote
Old 02-20-2019, 12:02 PM   #20
Grumpy old man
Yes , Minor , Just run a 9/16 drill up thru the holes from the bottom .
Old 02-20-2019, 12:05 PM   #21
68 P.O.S.
Possibly. Some trucks do, some don't. Mine did. Use a 9/16" drill bit, you won't have to do much an it's not hard
