Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-19-2019, 05:27 PM   #1
forestb
forestb's Avatar
speaker whiring
I recently purchased a kicker amplified controller (specs are below). It has wires for only 2 speakers. I have 4 speakers in my truck. I need help figuring out how to wire them. I have 2 KS Series 4" Coax speakers in the kick panels (specs are below) and 2 Boston Acoustic 3" Speakers (4ohm, 15W nom., 30W peak with 13 mm tweeter) in the dash (specs are below). They show 2 ways of wiring them and I don't know which one to do or maybe something totally.
forestb is offline   Reply With Quote
Old 02-19-2019, 05:29 PM   #2
forestb
forestb's Avatar
Re: speaker whiring
Specs for the 4 inch speakers
Old 02-19-2019, 11:45 PM   #3
BIGglaSS
BIGglaSS's Avatar
Re: speaker whiring
Ideally, you would use 1 speaker per channel. However, your amp is 2 ohm stable, so wire them in "Parallel" per the diagram you posted. 2 speakers per channel.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 02-20-2019, 12:39 PM   #4
forestb
forestb's Avatar
Re: speaker whiring
When doing this would I have the wires for the second speakers coming out of the plug that connects to the first set of speakers?
Or can it branch off from the wire?
Does it matter if the wires go to the 2 ohm speakers first or the 4 ohm speakers first?
Old 02-20-2019, 01:16 PM   #5
forestb
forestb's Avatar
Re: speaker whiring
Also the the Boston speaker are not marked as positive or negative at the terminals. How do I tell which one is which?
Old 02-20-2019, 10:00 PM   #6
67ChevroletDude
67ChevroletDude's Avatar
Re: speaker whiring
I'm not sure how Boston does it but normally the larger terminal will be stamped positive on the terminal itself of somewhere in the vicinity/is positive, and whichever terminal has the wire soldered to it will be positive.
Edit:just looked at a newer pair of Boston's and the large terminal is positive and small is negative.
67ChevroletDude is offline   Reply With Quote
Old 02-20-2019, 10:46 PM   #7
forestb
forestb's Avatar
Re: speaker whiring
Old 02-21-2019, 12:45 AM   #8
BIGglaSS
BIGglaSS's Avatar
Re: speaker whiring
Wire it just like the diagram you posted. Both the Boston and Kickers are 4ohm. Put one of each on each channel. 4 ohm + 4 ohm in parallel = 2 ohm load on the amp.
Old 02-21-2019, 12:32 PM   #9
forestb
forestb's Avatar
Re: speaker whiring
Awesome thinks for some reason in my head I keep thinking the Bostons are 2 ohm when they are 4. Sorry for the confusion.
