Old 02-25-2019, 08:28 PM   #1
demian5
demian5's Avatar
CPP Deluxe Track bar on a 60-62
Has anyone installed a CPP 1960-62 deluxe track bar on their truck and be able to use the factory shock mounting points at the rear of the trailing arm?
Here is what I am dealing with. CPP had no answer and said they never ran into this issue.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-26-2019, 01:03 AM   #2
Captainfab
60-66 Nut
Re: CPP Deluxe Track bar on a 60-62
I would say that you will need to move the lower shock bracket back. Drill a hole in the lower CPP bracket for the rear hole in the shock bracket and drill a new hole in the shock bracket for the rear leg of the u-bolt. Having the shocks more vertical is better anyway.
Old 02-26-2019, 02:16 AM   #3
DakotaKid
i just modified the bottom of the CPP bracket to clear the shock body on mine.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 02-26-2019, 11:51 AM   #4
demian5
demian5's Avatar
Im having both shock brackets extended so they match.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 02-28-2019, 01:25 PM   #5
demian5
demian5's Avatar
After no guidance from CPP, we extended the lower shock mounts.
Seems to have solved the issue and put the shocks at a better angle.
1986 C20 Scottsdale
Instagram: C10sofOC
