Old 02-27-2019, 10:35 AM   #1
chewychevy67
Adding 72 door panels to 67-71 doors questions
For those who have Done this I have a few questions. Can I use the existing holes where the metal panel bolts in as pilot holes for making the bigger holes for the clips on the 72 panel? Also what size holes are needed for the clips and does anyone know where clips that work properly are available? Thanks in advance.
chewychevy67 is offline   Reply With Quote
Old 02-27-2019, 09:22 PM   #2
franken
Re: Adding 72 door panels to 67-71 doors questions
No answers but my understanding is the 72 window regulators and maybe the door handle spline thing stick out farther than earlier years. I'm not positive though.
Old 02-27-2019, 09:24 PM   #3
Sheepdip
Sheepdip's Avatar
Yes they do stick out further. You have to change out the whole window regulator and door handle mechanism.
Sheepdip is offline   Reply With Quote
Old 02-27-2019, 09:41 PM   #4
chewychevy67
Yes I have those things already I'm just concerned about getting the panel mounting holes in the correct locations in the door.
Old 02-27-2019, 10:14 PM   #5
CUSTOM/10
CUSTOM/10's Avatar
I did this many years back, and if I remember correctly I drilled out the existing threaded holes for the older metal panels to accommodate the plastic push in mounts for the 72 panels. I don't remember the size drill, I most likely did it by trial and error. I do believe theses doors are still on my old rusted out truck in the yard, and could take a look at them this weekend if you need.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 02-28-2019, 07:58 AM   #6
uncle
I did this years ago also but pretty sure I found a plastic clip that had smaller diameter stud,so I never drilled threaded holes in bottom of the door. Check at automotive paint store for clip selection.
uncle is offline   Reply With Quote
Old 02-28-2019, 10:36 AM   #7
chewychevy67
That's interesting. I may have to look into that
Old 02-28-2019, 11:37 AM   #8
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The 72 nylon push pins can be had here, http://www.manestruckparts.com/store...&Category_ID=7 I'm pretty sure these guys have them as well https://www.classicparts.com/Door-Pa...oducts/267/5/0
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-16-2019, 10:22 AM   #9
chewychevy67
Can anyone tell me what exact size drill bit I need to drill these holes to factory size for the clips to mount the panel properly please?
Old 03-16-2019, 10:30 AM   #10
ls1nova71
ls1nova71's Avatar
They're just a touch over 1/4", so 1/4" should work.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-16-2019, 03:22 PM   #11
chewychevy67
Perfect thanks!
