Old 03-04-2019, 06:17 PM   #1
SCOTI
SCOTI's Avatar
Air Cleaner Duct Tubing
Anyone have a p/n or source info for replacement air cleaner inlet ducting? Since these trucks had the round to oval transitions, I'm curious if there was an aftermarket duct-hose that adapts easy enough.
Please..... No 'wrecking yard' recommendations. 99% of any squarebody in a yard is plucked of useable stuff these days if you can even find a yard w/a square. If you're lucky enough to actually find a square, the heat/elements typically render the same quality plastics under hood that we're trying to repair.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-04-2019, 07:58 PM   #2
Re: Air Cleaner Duct Tubing
LMC had it for V8 models last time I looked. The 6 is slightly smaller and did not see that size in their catalog.
Old 03-10-2019, 12:07 PM   #3
tucsonjwt
I got my OEM air cleaner duct for my 83 C20 from a place called Vintage Parts.
They sell some obsolete original car parts and even parts for old appliances.
You must have the GM part number to search for parts on their website. My duct was not cheap (about $35 as I recall) but it was the correct duct for my truck.
tucsonjwt is offline   Reply With Quote
Old 03-11-2019, 09:47 AM   #4
SCOTI
SCOTI's Avatar
Thanks for the suggestions.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-16-2019, 02:10 PM   #5
Pontiac1976
Pontiac1976's Avatar
I need one too for duel air cleaner I had one keep going yards and boards could no find one so I order one from LMC after two years of looking. There a little thinner made.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-16-2019, 02:37 PM   #6
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
The LMC one looks like the pre-TBI air cleaner as it lists 1981-86. Has anyone found the TBI style ducting?
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 03-17-2019, 08:35 AM   #7
Pontiac1976
They have both order the right one you need. I got the long straight one. Not the TBI! because I running two tubes to the duel air cleaner to get more air in.
