#1826 |
Re: How to: Ruin a perfectly good C10
I like it! Nice job of hiding the ugly stuff. Are you doing the water pump orange and the accessories black? or?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#1827 |
woah, it's been a while since I checked in... 3 pages (well 2 really) of updates that I've missed out on. Looking good! I love the valve cover treatment and the hidden items on the intake. I like the orange engine myself.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#1828 | ||
A guy with a truck
Water pump will be orange, brackets/pulleys black, alternator case ‘aluminum’ to break it up a bit, unless I decide I hate it, then it will get painted black. Same goes for brake and clutch masters, alloy for now, unless they bother me too much then they’ll end up black. Quote:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#1829 |
A guy with a truck
More progress, albeit small. I found some nickel plated 1/16” npt fittings to use for the steam vent, instead of buying the $100 AN hose kits that are for sale everywhere. I lopped off the long, stock nipple and used an elbow, then plumbed a straight fitting into the water pump. Short, sweet, and to the point.
Also installed the oil filler in the valley cover, which I’m kinda on the fence about, but the hole is drilled, so that’s that. It’s all in the details... Maybe I’ll be ready to stab this thing, soon.
#1830 |
I like it, probably the cleanest way to do the steam vent. I like the oil fill, too. If you don't like it after the 30-day rule, you could always pull the valley cover and weld in a tube to mimic the old style fill tubes.
#1831 |
Shaping up nicely.
#1832 | |
A guy with a truck
Thanks, I’ve been looking at yours and stealing ideas ![]()
#1833 |
A guy with a truck
Finally tore into the packaging of these beauties today and promptly set to tearing them apart and scrubbing them with 220 grit sandpaper. Why would a seemingly sane person do this to a $700 set of billet hood hinges, you ask? Why to paint them black to make them look more like stock, of course
![]() I squirted the hood hinges (and the ICT billet engine accessory brackets) in my favorite shade of satin black. Hopefully tomorrow they are cured enough to reassemble...
#1834 | |
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#1835 |
![]() Join Date: Feb 2011
Great job on the retro & simple look on the engine...just goes to show you dont need copious amounts of billet & chrome!!!
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#1836 |
A guy with a truck
Thanks, and hope you guys like the finished look of the hood hinges as much as I do. I think they should have come this way:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-05-2019 at 02:09 AM. |
#1837 |
A guy with a truck
I also installed the painted accessory brackets and came to the conclusion that I will need to paint those shiny bolt heads black, too
#1838 |
I'm just glad to be here!
The hood hinges turned out very nice!
paint that rusty damper bolt too...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#1839 |
I love the overall theme! I feel the same way about scuffing brand new billet parts for satin paint, it just fits...bet it makes some folks skin crawl though!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#1840 |
Nice work! I have to wonder why you did all that work though, aren't those hinges offered in black powder coat? Mine did, but I have the Eddie Motor Sports hinges. Either way, it looks good, and the engine is turning out nicely!
#1841 | ||
![]() Quote:
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() Last edited by TA_C10; 03-05-2019 at 11:27 AM. |
#1842 |
I'm Lovin' It!
#1843 | ||||
A guy with a truck
![]() Quote:
![]() Quote:
![]() For the masking part, I used no tape, mostly stuff I had laying around. Pictured below are some of the tools; the washers fit perfectly in the bearing-face holes, held by the counter-sink screw and nut which fit perfectly in the backside of the bearings. All other threaded holes had bolts installed, or 3/8-16 j-hooks which were used to suspend the parts while spraying. It’s like a McDonalds commercial ![]()
#1844 |
Chris, the black finish on the hinges is just what the doctor ordered
#1845 | |
A day late and $1 short...
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#1846 | |
A guy with a truck
I’ve always been a cheap-a$$, but now I can afford better parts ![]()
#1847 |
While I like the minimal bling effort, I feel painting the bolt heads creates areas for future failure. Plated bolts are fine (quality plated) & you don't have the chipping/peeling issues if something requires adjustment. Food for thought.....
#1848 |
A guy with a truck
Sage advice, as always, Scot. Maybe I’ll find some black oxide replacements
#1849 |
Good idea but be warned..... most I've used are of poor quality & rust easily. I used the Black ARP header fasteners on my dually. 1st time I rinsed the engine compartment down they were rusty within days. I wound up only using their studs & after buzzing the surface rust off, painted them w/engine high-heat paint. I swapped all the remaining hardware for SS. I had higher expectations given ARP was the source especially given the cost as there were more cost effective alternatives.
#1850 | |
A guy with a truck
