Old 03-05-2019, 05:35 PM   #1
Bpilcher72
Bpilcher72's Avatar
Hydroboost Pushrod Removal
Does anybody on here know how to remove the pressed in hydroboost pushrod? I purchased a new GM Unit and want to install an adjustable shaft with a clevis on the end. I have heard rumor of a Kent Moore tool that is used to pull the pushrod out of the socket. Anybody on here have experience with that?
Bpilcher72 is offline   Reply With Quote
Old 03-05-2019, 06:17 PM   #2
Chris_oz
Chris_oz's Avatar
Re: Hydroboost Pushrod Removal
From memory the push rod is held in with a "stake" into an thin walled retainer.
I had to make a shorter one for my application (Cadillac).
I am sure I put a sleeve over the rod, clamped the rod with vice grips and used a pair of pry bars to pop it out. It came out very easy too.
I just made a new one from a 3/8 grade 8 bolt, threading the clevis on the thread and machining a new ball in the lathe.
Works perfect
Good luck.
Chris_oz is offline   Reply With Quote
Old 03-05-2019, 08:30 PM   #3
Bpilcher72
Bpilcher72's Avatar
so you are not just prizing on the shaft you have to remove a retainer pin also?
Old 03-05-2019, 08:42 PM   #4
Chris_oz
Chris_oz's Avatar
Mine didn't have a retainer pin, Just a ball on the end of the shaft in a matching socket and a swagged in crimp just above to retain it.
The crimp is only required for assembly, once installed the the rod is going nowhere if the lengths are all correct.
Old 03-05-2019, 11:10 PM   #5
clay68c10
clay68c10's Avatar
The version I have isn't swedged in but has a retaining ring made of some kind of hard-core semi flexible nuke proof death plastic.
I put the unit in a vise and used a very long 3/8 extension thru the ring and plenty of a$$ to pop it out. Very scientific. Make sure you are getting a nice straight pull inline with the rod or you will get a hernia and it won't come loose and you will want to smash things with a big hammer.
Have fun.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
