#576 | |
![]() ![]() Join Date: Apr 2012
Re: The 1960 - 1966 Chevrolet & GMC Pickups Factory Correct Restoration Thread
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#577 |
Tried to install my new kicker audio stereo and realized that I am not smart enough to install it but I am smart enough not to try��
I don't know why this got posted here. It was supposed to go to the what did you do to your truck today thread. Last edited by forestb; 02-22-2019 at 12:23 PM. |
#578 |
![]() Join Date: Jun 2011
hate to point this out but the center A/C vent is installed backwards
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
#579 |
![]() Join Date: Sep 2002
LT1, do you have the correct nuts that mount the AC box to the firewall?
Could you show me what they look like? I have two styles on mine and can't tell if either one is correct. This pic of yours shows which ones I am referring to. Thanks! Last edited by damnyankee36; 02-23-2019 at 12:08 AM. |
#580 |
Jon(60-66) would be the guy to answer this, he has an NOS AC kit and will have all the hardware with it new.
#581 |
I did look at his "Dealer Installed A/C" thread earlier. No pics of the nuts, but the diagram, along with the AIM, shows what looks like a flange/washer nut. The nuts previously installed were this type of nut and a stamped, (for emblems?) type nut.
I just went to Lowe's and found a couple of free-spinning flange nuts. |
#582 |
![]() Join Date: Aug 2013
#583 |
try the local smaller harware stores they may have the correct items, found a set on a pick the other day.
#584 |
You're saying this is the correct nut?
#585 |
yes it came off a heater box from a 66 C10 i always take bolts screws and washers from trucks when i pull parts, in order to have the correct one and if one is missing then i got to the hardware to match it.
#586 |
Hmmm, I was gonna assume that this type of nut wouldn't be to bolt on something that heavy. Emblems, maybe.
Guess I'll rethink this again. They are easy to find, however. Thanks for the tip. |
#587 |
Winston is correct about the nut. Its more about sealing force than supporting weight since the weight is carried by the studs. Theres also support from the bracket to the dash. Lowes nuts are all wrong for this.
#588 |
these hold the box on the engine side
#589 |
Close enough for me. Sometimes you have to decide when to draw the line...
I bet if you could find them repro'd they wouldn't be much better! Thanks for all the info. |
#590 |
you just made what i call a "work around". finding a product thats available now to meet the same goal and look almost like the original. nice...
#591 |
i think its more on this thread to find the factory correct item, because i have a work around. i just like pulling parts and get the item as it came.
#592 |
Well , that's why I have "parts trucks" I rarely if ever use store bought fasteners when putting one of these back together in "original" form. I Reuse many original nuts and bolts with the correct head markings and size and simply clean and replate them. Makes a BIG difference when you see any restoration done. My biggest turn off is seeing a restoration and every nut and bolt was bought at the local hardware store , all of your local hardware is now Chinese and is NOT the same thread pitch or diameter most the time. Theres a company that actually makes most of these fasteners exact. Pretty big catalog selection right down the the head markings and GM part numbers if you needed something speciphic. I will try to get that info and post it later. If you're doing a restoration , its worth it , resto mod or modified , who cares.
#593 |
#594 |
My parts trucks are bone yards close that still has originals no one cares bought other then me, I been pulling parts at this one spot for 3 yrs and there’s still more there.
#595 | |
http://www.amkproducts.com/Catalog_PDF/56-73.pdf
#596 |
Active Member
![]() Join Date: Jan 2017
On my 1965 K20, listed next to "Paint" on the kick panel plate are the numbers 80-72367 and 96890. Does anyone know what these numbers mean?
Submariner616 1965 Chevrolet K20 350 4 speed manual |
#597 |
Active Member
I have searched the numbers and have tried to find a match on every 65 Chevy paint color sheet I could find with no luck.
#598 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Usually codes like that are a FLEET color or Government issue . state rescue and such not. What original color is on the truck now?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#599 |
![]() Join Date: Sep 2016
There wouldent happen to be a round inside cargo lamp lens? I broke mine from my 62 suburban.
#600 | |
Active Member
Submariner616 1965 Chevrolet K20 350 4 speed manual Last edited by Submariner616; 03-06-2019 at 02:25 AM. |
