Old 06-03-2002, 12:28 AM   #1
Fast68Chevy
Fast68Chevy's Avatar
how to separate outer bedsides from inners ?
on fleetside long beds has anyone separated the outer sides before, i know pont has i think, ayone else ? how many spotwelds and where ? i need to snag these sides off this bed since they are clean no rust, so i can sell them or whatever and scrap the floor and rest of whatever else is trashed
thanks
Fast68Chevy is offline   Reply With Quote
Old 06-03-2002, 09:07 AM   #2
snow man
Cool bed sides
the sides unbolt there are two tack welds at the back were tail gate mounts. did you check my post under fast poll?will you be there during the day this week?let me know so i won't drive over and you not be there.
snow man is offline   Reply With Quote
Old 06-03-2002, 09:11 AM   #3
Low69CST
Also the inner wheel tubs bolt up under and inside the wheel wells, does that make sense?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-03-2002, 01:49 PM   #4
Slammed67
Progress = 0%
Slammed67's Avatar
I think he means separating the inner and outer skins, not removing the whole bed side. Right?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 06-03-2002, 09:26 PM   #5
Fast68Chevy
mark, i will be here all the time, i wont be here tuesday from 1-2:30 or so, funeral to go to.
otherwise wqil be here all the time, only gone for bits of time at a time to go get stuff or whatever
yeah i mean removing bedside skin outer one only
looks like are tacks inside the arches too for the filler deal in there
thanks for any other info, i hope to be pulling 71 out of shed soon to dismantle/torch it and put aunt's trans am in there to store it, i got farther along on cutting up 70 shorty today than i thought i would
thanks
Old 06-06-2002, 11:35 PM   #6
Fast68Chevy
ttt, need to know details from someone who has removed outer bedsides
thanks
Old 06-06-2002, 11:46 PM   #7
Gee_Emm
I have done this. There are about a million spot welds along the top rail if I remember correctly. I I had to peal the outer panel lip up. It is ALOT of work to do. I havent mated up the good inners that I was trying to save with a decent outer yet. I kinda doubt that I ever will put them back together, I think it would be alot of work and wouldnt turn out all that good. Probably easier to look for a bedside with both good inners and outers.
Gee_Emm is offline   Reply With Quote
Old 06-07-2002, 12:33 AM   #8
PushinPebbles
My dad's 68
PushinPebbles's Avatar
try a air chisel..........i guess so............fairly cheap
Jack
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
grand dads truck 68 C-10 stepside
fuel inj. 350/700R-4*soon in audi silver*
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
Old 06-07-2002, 12:01 PM   #9
Fast68Chevy
hmmmmm........ crappy....
well reason i ask is because i got pair of longfleet sides that are no rust, but couple dents.. hmmm.... was gonna see about selling them and not scrapping, but oh well,...
thanks
Old 06-07-2002, 02:18 PM   #10
Low69CST
To remove the skins you have to drill out about 100 spot welds on each, bend and pry the crap out of each and try to not bend the crap out of each. The amount of time and hassle would be about 5 times more than if you just removed each bedside, Plus i've never heard of anyone just replacing a bed skin, most people will repair the inside part to save the hassle.
Old 06-07-2002, 07:09 PM   #11
da-burb
"Ochre Ogre"
da-burb's Avatar
If they are that nice you would be better off to cut them up as patch panels. They should still be better than using re-pop panels.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 06-12-2002, 01:58 PM   #12
Woody
The way I see it, I would cut the inside panels about 3-4 inches down the side. That way you could use them with some inners that you cut above that and over lap them. Then screw them together up near the top inside under the rail. This would hide the seam very well.
Woody is offline   Reply With Quote
Old 06-13-2002, 02:17 AM   #13
Fast68Chevy
guess will have to use the 7" cutting wheel on the big ass right angle drill deal,...
need new wheel first though, or maybe i have some here, hmmm... i forgot if i got extras last time i went to Big R store,.
thanks guys
