Old 03-10-2019, 01:29 PM   #1
Big70
Drive line from long bed to short bed
OK so I’m going to be cutting my long wheel base to a short wheel base and I have a two piece drive line. So my question is Do I go to a single piece driveline when I shorten it and if I do what do I do about the driveline cross member? I Will be using the brothers shortening kit. I was thinking that I’m going to need to go to a single piece based on I’m running a 468 was probably about 500 horse and thought it might be a better idea just going to a single piece driveline any help and or tips much appreciated thank you
70 custom10 swb fleet side 454 th400
Big70 is offline   Reply With Quote
Old 03-10-2019, 01:33 PM   #2
Jrainman
Jrainman's Avatar
Re: Drive line from long bed to short bed
single drive line and I believe if I remember rite if you have the th 400 crossmember no need to do anything after installing your brothers short bed kit
Jrainman is offline   Reply With Quote
Old 03-10-2019, 03:09 PM   #3
rjs53
I went with a one piece driveline after I shortened mine. It was around $300 and that everything new.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 03-16-2019, 03:18 AM   #4
Big70
What did you do about the cross member? You know where your old two piece drive line went threw?
Old 03-16-2019, 07:25 AM   #5
rjs53
I took the carrier support out, don't remember if it was bolts or rivets. did a 4/6 drop and plenty of clearance around driveline running thru cross member
2003 Dodge 2500
1969 C10
Old 03-16-2019, 10:18 AM   #6
p0508
A few rivets and you can knock out the carrier support.
p0508 is offline   Reply With Quote
