Old 03-10-2019, 02:17 PM   #1
kens65fb
Wheel offset ?
I'm going from 6 lug to 5 lug brakes.
I need to get find some 5 lug ---15 inch wheels
What offset will work best with a 15 X 7 wheel
kens65fb is offline   Reply With Quote
Old 03-10-2019, 07:33 PM   #2
PGSigns
PGSigns's Avatar
Re: Wheel offset ?
The ones on my 66 are 3" i think. It is 6 lug still with front disc so that part is the same.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-10-2019, 09:10 PM   #3
1slo64
Re: Wheel offset ?
I usually go with a 0 offset on a 7" or 8" wide wheel.
1slo64 is online now   Reply With Quote
Old 03-11-2019, 06:57 AM   #4
kens65fb
Re: Wheel offset ?
What backspacing would work best?
Old 03-11-2019, 10:50 AM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Wheel offset ?
Maybe this will help clear up the difference about backspacing and offset. It has a good chart to convert them as well.
https://www.discounttiredirect.com/l...fset-backspace
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-11-2019, 04:40 PM   #6
Cris
Re: Wheel offset ?
Depending on how much tire you want to fit under your truck, you have some flexibility on backspacing. That said, if you want to maximize the tire under your truck, that is, move the tire inboards as much as possible, a backspace of around 4 3/4" is about as much as you can go. This will depend a little on your tire selection, wheel diameter, and brake system.
If you know the backspace of your present wheels, crawl under the truck and measure how much room you have to move the tire/wheel inwards or outwards. Be sure to go lock to lock. You'll get a good idea of what you can fit.
Backspace is measured from the (outer) lip of the inboard side of the wheel to the mounting face of the wheel. To measure, place a ruler that spans the inboard wheel lip and then with a second perpendicular ruler, measure the distance of that ruler to the wheel mounting face.
Cris is offline   Reply With Quote
Old 03-11-2019, 04:52 PM   #7
kens65fb
Re: Wheel offset ?
Thanks, that explaination was just what I needed.
Old 03-11-2019, 08:39 PM   #8
PGSigns
PGSigns's Avatar
Re: Wheel offset ?
4" back spacing on a 15" wheel will the lower control arm if you go to 2 1/2" drop spindles. That is why I am running 3". So the overall plan for the suspension will affect the wheel choice.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-12-2019, 11:05 AM   #9
kens65fb
Re: Wheel offset ?
Jimmy
I currently have disc brakes on my 64 (stock height spindles)
I have ordered a set of 2 1/2 inch drop modular spindles from CPP, as I want to lower the front end.
The current wheels & tires fit fine.
Presently I'm running :
Tire 225/60/15
Wheel 15x7 --- 6x5.5 bolt pattern ---3.5 backspace (-9.00 offset) 4.252 ? 108 mm center bore
Will the addition of the drop spindles introduce any wheel or tire issues ??
Also if I install 1'or 2" drop springs in addition to the drop spindles, will I need to order drop shocks, and shock relocation brackets.
These are my wheels
