Starter not engaging,but not all the time!
Is my starter going bad or do I have a bad spot on my flywheel?
Sometimes, not always when I try to start my truck the starter will whine but not engage. Second try usually will start the truck. I guess if teeth were missing on the flywheel it might not ever engage unless the flywheel was rotated some, is this right? Thanks inadvance! |
![]() ![]() Join Date: May 2015
Re: Starter not engaging,but not all the time!
Bendix is bad most likely...
If the starter spins, but doesn't engage the flywheel, the gear is not popping out.
If it grinds really bad, I would look at the flywheel and spacing.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
as mongo said, your Bendix is going bad
#5 | |
Thank you mongocanfly, rpmerf, Big Moose, and bigdaddy4X4. I am off to get a replacement starter.
![]() Join Date: May 2012
This is just my opinion, but if I have a starter on a vehicle that seems to "fit" good, as in sounds good when starting(when it works) and doesn't grind-sounds like it meshes good with the flexplate or flywheel, I would rather rebuild or have rebuilt the starter I have rather than getting a different one. I have had too many problems with replacements need shimmed to get them to sound right when starting....It can be a real pain to get them right.
Moderator
![]() Join Date: Oct 2008
I would keep your old starter even if you get a re-built unit. The Chinese crap has poisoned the supply chain to the point that even an otherwise quality reman unit may not fit properly.
You can usually get yours re-built locally so you end up with a starter that actually fits.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Mine did that for a while and eventually started engaging but not disengaging, had to pull the battery cable off to get it to stop cranking.
I had luck taking the starter apart and turning all the contacts inside around to a fresh side (they were reversible in my starter). |
