Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-14-2019, 05:59 PM   #51
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: C20 to K20 Conversion "Simply Toxic"
Nice build and great work on it! Nice work on those cab mounts. I have a 72 gmc cab that is on a 03 half ton burb chassis and the guy put the front cab mount bolt straight through the frame. It works, but IDK if I'll complete the project or separate it.
Ryan
1969 Chevy milk truck
Old 02-15-2019, 08:32 AM   #52
JustToxic
JustToxic's Avatar
Thanks Dieselwrencher, I did a good bit or research on how the cabs fit the frames before hand. Came up with something that looked better then some of the ones I saw. If I was to this frame swap again I think I would have picked a burb or a avalanche frame to start with.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 02-25-2019, 09:00 AM   #53
JustToxic
JustToxic's Avatar
Worked out in the garage almost all day Saturday tearing the cab apart. Found a bit more rust, so I need to order a few more pieces before I can start going back together. I want to thank 72_tigger for helping with the cab last weekend. Not going to explain all the rust, I'll let the pictures do the talking.
Old 02-25-2019, 09:01 AM   #54
JustToxic
JustToxic's Avatar
A few more pictures of the rust.
Old 02-25-2019, 09:31 AM   #55
landarts
landarts
Nice job on the cab mounts and I really like your rotisserie the cab is on. That will really help in repairing the rust on the cab. Nice job!
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
69 K20 Custom Deluxe 4x4
71 K10 Custom Deluxe
72 K20 Crew Cab Project
71 GMC Jimmy CST
70 Blazer
landarts is offline   Reply With Quote
Old 02-25-2019, 10:18 AM   #56
JustToxic
JustToxic's Avatar
Thanks landarts, glad I took someones offer on letting me use the rotisserie, its made life way easier.
Old 03-11-2019, 08:34 AM   #57
JustToxic
JustToxic's Avatar
Figured after two days of working on the cab I'd have more done. I got the new driver side floor welded in and the cab corner started. Still have to do everything to the passenger side.
Old 03-11-2019, 01:04 PM   #58
72 tigger
72 tigger's Avatar
Making good progress- always surprising how much thin metal you find when you dig into it
72 tigger is offline   Reply With Quote
Old 03-11-2019, 02:03 PM   #59
JustToxic
JustToxic's Avatar
Yeah, the more I vibrate the cab taking the driver side apart, the more I see I need to replace on the passenger side. Just ordered a floor board for the passenger side, it looks like Swiss cheese since I took the rocker off.
Old 03-13-2019, 09:57 AM   #60
JustToxic
JustToxic's Avatar
Forgot to post the floor pan pictures the other day. Got the rocker and cab corner lined up last night. Need to take the outer rocker back off to finish the inner rocker. Give everything a final grind, then time to move on to the passenger side.
Old 03-13-2019, 11:33 AM   #61
landarts
landarts
Floor patch looks great, keep up the good work on bringing it back to life.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
70 Blazer
Old 03-13-2019, 12:54 PM   #62
72 tigger
72 tigger's Avatar
Nice work- do you think you should take the cab off the rotisserie and mount the doors before you weld the outers on? Just to make sure everything lines up? Just my .02
Old 03-13-2019, 01:15 PM   #63
JustToxic
JustToxic's Avatar
Normally I would say yes to taking the cab off and fitting the doors first. But in my case the bottom of the doors are rusted out and I have all the metal to fix them, so I'm just going fit the doors to the cab. Kind of a backwards way of doing it.
Old 03-13-2019, 01:16 PM   #64
JustToxic
JustToxic's Avatar
Old 03-14-2019, 08:40 AM   #65
JustToxic
JustToxic's Avatar
Finished up the Driver side last night, now just have to seam seal and grind everything smooth. Should see the new passenger side floor board before the weekend, hopefully be able to get that started and finished in the next week.
Old 03-14-2019, 11:36 PM   #66
franken
Looks great!
Can I mail you my truck?
Mine's slightly better to start, but even southern ones rotted.
franken is online now   Reply With Quote
Old 03-15-2019, 07:28 AM   #67
JustToxic
JustToxic's Avatar
Thanks, I don't think there are too many of them that don't have rust on them.
Old 03-22-2019, 10:01 AM   #68
JustToxic
JustToxic's Avatar
No pictures to post today, but after having to wait to get a second passenger side floor board shipped to me, I got the passenger side installed last night. Got both in from Fedex damaged so I ended up using the one with the least amount of damage.
Old 03-25-2019, 07:50 AM   #69
JustToxic
JustToxic's Avatar
I got the passenger side floor board welded in and the passenger side rear cab cut completely out this weekend. Was only able to work on the truck here and there as the wife wanted to go to IKEA and furniture store. But first couple pictures are of the completed driver side I forgot to post. Then some in process of the passenger floor.
Old 03-25-2019, 07:55 AM   #70
JustToxic
JustToxic's Avatar
Shows how much I had to cut out of the passenger side cab corner. I have to remove the plates that are in the back of the cab too and weld in some new metal under them. I followed a bunch of rust the more I cut into it. Since the new rear cab support isn't exactly the same as the original, I decided to put the cab corner on first and make sure that is all lined up before I messed with the floor and brace.
Old 03-25-2019, 10:04 AM   #71
JustToxic
JustToxic's Avatar
Almost forgot to post this. Decided to scrap the Dana 44 front axle, went and bought a Dana 60 king pin axle. Came out of a '79 Ford F-350.
Old 03-29-2019, 10:43 AM   #72
JustToxic
JustToxic's Avatar
So this passenger side has been fighting me the entire way. The lower A-pillar and B-pillar are completely different then stock. To the point I had to cut the B-pillar apart and add metal to it, and on the A-pillar I'm going to have to modify the outer rocker. Once I figured that part out I ended up building a piece for the rear of the cab and modifying the inner rocker piece. Still need to grind the welds and do a bit of metal finishing and it'll be all good. Have I said how much I like this re-stamped metal yet?
Old 03-29-2019, 09:34 PM   #73
72 tigger
72 tigger's Avatar
You’re burnin’ up some wire! Going to be a solid cab when you’re done
Old 03-30-2019, 02:52 PM   #74
landarts
landarts
Looking good, a little grinding and paint and she will be like new again. Nice job saving this one!
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
70 Blazer
Old 04-02-2019, 11:21 AM   #75
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Subbed
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
