Old 03-18-2019, 09:30 PM   #1
cerial
cerial's Avatar
Aftermarket Big fuel gauge
Doing a ls swap with a custom dash pulling all the old electronics out of my 87v10.
I want switches and a large dual battery marine master disconnect switch to the left side where the small gauges currently are. Switches going down from there on a removable panel for easy maintance.
Where the speedo/fuel gauge currently is I am just going to run a old Garmen which will display speed/mileage at key on with a large fuel gauge next to it.
There is a screen on the garmen which just shows mileage and speed. I ran one for over 400k without fail before driving OTR. Thing will load right up(vs torque), auto dim, and accurately record my speed/mileage no matter the ratio or tire size I feel like running during the summer/winter. Not bad for $20.
Where the heater control/radio is I will run a old phone to run torque pro off the obd2 port for gauges(once they load) and a modern removable phone for navigation/speed limits(waze) spotify/downloaded songs plugged into a 3.5 jack to play through a cheap deck tucked behind the glove box. Using a slider on the phone for volume with the deck always at max.
I am strange. I like that big (no tach) fuel gauge. I don't want a puny 2" one. That being said I cant find any freaking aftermarket ones that are that size.
Does anyone make a Big aftermarket fuel gauge?
I honestly did not think this would be such a pain to find one the factory size. I guess I can just buy a $50 one from LMC, make a housing for it and while there drill some holes into the face for turn/bright/4wd indicator leds. Thats plan B at this point.
But if I could get a 270 degree one that size I could just drop in/wire up it would really make me happy.
Sending unit is a 1972 0-90 ohm.
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 03-19-2019, 08:59 AM   #2
raceman6135
Dino burner
raceman6135's Avatar
Re: Aftermarket Big fuel gauge
The largest stand-alone fuel level gauge I'm familiar with is from Speed Hut, and it's 3 3/8" diameter:
https://www.speedhut.com/gauge/GL338...(programmable)
I'm guessing you're looking for something closer to 5" in diameter, though. I don't know if one of those exists, but you're asking on the right board! Hope someone has something else to offer.
raceman6135 is offline   Reply With Quote
Old 03-19-2019, 09:14 AM   #3
cerial
cerial's Avatar
I forgot they made one that big.
Yes that will work. It is smaller but has more sweep at a cost around what making a custom housing for that factory gauge would put me.
Will order it tonight.
1991 Metro commuter
