#26 | |
Re: Blazer Chalet #0661
but but but i saw them do it in 7 days on tv . . . why cant i do this and make money ..... thats whats wrong
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#27 | ||
Active Member
![]() Join Date: Jul 2015
It's really not too big of deal. We knew there was some rust and bondo and our body guy knew it too and quoted it accordingly so it's not like it's gonna be a big surprise bill. Was just surprising to see what was underneath. Floorboards were in pretty good shape along with the bed. Fenders are more work that what they were worth, gonna have to find some take offs. Drivers door needs repaired where the old mirror used to be. Passenger door seemed to be the only good panel on it.
'75 C10 SWB 454 '75 K10 SWB "The Gilded Turd" '77 K5 Blazer Chalet #0661 Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=776072 '79 K10 Bonanza |
#28 |
Active Member
Few more....
#29 |
K5Camper
![]() Join Date: Mar 2004
Great progress for sure. Bummer on the hidden fun under that shiny paint, but it's getting fixed so all will be well.
I'm curious what the end game will be. I know you and the wife want to use it for camping. Is that going to be full on using it off road to get to back country spots, or some milder forest roads and the like? Any plans of beefing up suspension/axles for durability and strength? Not saying going nuts for a D60/14bff combo, but 3/4ton axles at least. I think a 14bff would be indestructible under your setup and just adding 8 lug hubs to match on the D44 up front. Good work again.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
#30 | |
Active Member
The 3/4 axles we have talked about. It's on the list for the future but probably will be down the road. You're right it would be a really good setup. Here's some pics from the show.
#31 |
K5Camper
That's a good plan. I've always thought the Chalet's were a little too big to really go far off the beaten path like I do with my FWC camper. (which gets called a Chalet A LOT). I wouldn't want to put that fiberglass through the abuse I've stuck mine into this last year. (I've got a pine branch still on the roof rack from our snow run on new years day too)
The real chalet's like yours need to be preserved, used but not beat to death. I've followed a few threads where they got built up and then yanked off and set in a pasture somewhere. Kudo's for actually going through the effort to restore one. I like the plate # too. Nice touch.
#32 | |
Active Member
#33 | |
K5Camper
I would sure like the height you got with the top popped up. I'm pretty tall so with the top up on my FWC I'm brushing the roof with my head. Sleeping in the cabover section on mine is comfy with the right mattress, but It's still to short to sit upright up there. I'll fix both issues when I redo the canvas. I'll just add a few inches. I'm pretty darn careful off road now. Out in the desert where there aren't many trees, it's pretty easy. The mountains near me are a different story. Tree pinstriping is a given. But narrow jeep trails gain a whole other level of fun. I've got to replace the window screens on the passenger side from all the tree branches I've brushed up against this summer.
#34 |
Active Member
I know what you mean. When I dropped it off to the body shop the guy was talking about the basecoat/clearcoat and mirror finish while the whole time I'm thinking in my head, I don't want to hear how nice it's going to be and then all the scratches I'm gonna put on it. Made me cringe a little inside.
#35 |
K5Camper
Lots of clear my man. If Larry's k10 is any example I've seen, it's a good layer of clear. He and I have been down many of the same trails together and hit the same branches. He's polished it out a couple of times and it's still pretty sharp and it was painted over 15 years ago by a buddy of ours.
The idea is not to scratch it, but many times it's not avoidable. Best thing is to go slow and try to keep an eye on both sides. I've learned on some of the tighter trails to also watch which way the trail slopes. I've had to tread the needle between two trees but the trail sloped from left down to the right. Had I cheated more the the right the slope would have caused the roof of the camper to hit the tree on the right since the tilt pushed the roof over further at the top. So I hug the inside tree close on the uphill side sine the tilt puts me away from it and still have room to clear the downhill side. I won't lie, it can be nerve racking. But it helps if your passenger keeps an eye out too.
#36 |
![]() Join Date: Dec 2014
Beautiful truck, beautiful job you are doing with it. I need a Chalet, I have decided.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
#37 | |
Active Member
Thanks! Better grab one quick. Unfortunately I've seen prices go up on them even in the short time we started looking.
#38 | |
K5Camper
The rebuilt cabinet was truly overbuilt with thick plywood and solid oak face boards and doors. But inside those cabinets is a tote with cooking gear and other with other gear and food. All in all you can tell the truck has a slightly higher CG than it did before but it's not overly tippy. I put a lev-o-gauge on the dash and have put it in an upholstery sucking position a couple of times this summer, but it would have been the same with the stock top on. I play close attention to it though. In the sketchy stuff I rely on who's spotting me along with what I'm feeling inside. I've backed off and taken a different approach because it was spooky. Your setup is probably heavier empty than mine due to the fiberglass construction vs aluminum frame and siding in mine. Your CG will be higher than mine. Try to load gear as low as you can to offset the fridge and water tanks. You won't be doing the stuff I've done, so really sketchy stuff won't be a problem. You'll get a feel for it. Everybody has a different threshold for how much tippy is too much. What I wouldn't do is eliminate the sway bar like many do in all out off road builds. You need that bar there for the handling on road as the barn door is going to catch the wind like a sail. Off road, you don't want that truck to flex like mad with the high CG. The body will lean over and really make it tippy. I think for your intended plans you should be ok as you are.
#39 | |
Active Member
#40 |
Active Member
So we are going to go with a Hickey drop style hood on the Chalet. Waiting to find an original one in good shape and getting it to Oregon was not very feasible so we got a new one from Autofab. I think this will really add to the 70's styling we are going for. I messed around with some free online paint programs to figure out a paint scheme. We think we are going with the first one but would like to know everyone else's thoughts. It wouldn't have the thin black strip that is shown in the pic. That's just my lack of paint skills.
#41 |
K5Camper
Number 1 for me. Those hoods are sweet.
#42 |
I like the first one also but was wondering what it would look like with the brush guard paint the light cream instead of black.
Rick |
#43 |
Active Member
Back to work on the camper. Tear down of the Chalet to take in for fiberglass repair and paint.
#44 |
Man seeing those pics makes me wish I still had mine. But grad school and not very much $$$ was not conducive to having an extra vehicle that got 10mpg.
FYI, if you have not discovered it yet, there's a small triangular trim piece right behind the passenger seat, accessible once you flip the seat forward. It's held on by 3 or 4 screws. There's a cavity about the size of a small shoe box behind the panel. Makes a great place to stash extra cash when traveling. Also, what with the fridge in the rear, the main power cable runs beneath the body. Mine caught on fire (the wires) amazingly enough while I was under the truck. Lots of yelling at a friend to disconnect the battery (he disconnected the wrong one first) while I was blowing, swatting, etc. Anyway, I would put those wires inside a cable sleeve, especially if you plan on doing any four wheeling in it. |
#45 | |
Active Member
Pretty scary catching on fire while you are working on it. None of the camper accessories have been tested yet. After we get it back we plan on going through all the wiring and plumbing. Didn't want to light the furnace after 40+ years of rotten hoses. That would be my luck to burn it down after paint.
#46 |
Active Member
Door is pretty jacked up. Hopefully we can find the trim to redo the door frame. Not looking hopeful at the moment.
#47 |
Those rear doors definitely a weak point. I had issues with mine too. I seem to remember there is a wood frame inside them?
FYI, I found the fridge was not tremendously efficient as far as how long it took to cool down. Not surprising I guess given it's a mid 70's design and really old now. It might be worth looking to see if it can be replaced with a newer unit. I was always too worried about fire to think of using the propane heater option, always thought if I had kept mine now that I have money I would remove some things like the heater guts and insulate the heck out if the fridge, maybe run a heavy alternator and two extra accessory batteries to power fridge. I used to be off road camping in mine for a week at a time. Also, the interior lights I remember getting really hot - like almost burn your hand if you touched the metal reflector when you turned them off kind of hot. Would probably be well worth trying to find an led bulb for for comfort and less battery drain. I also thought that giant flat roof would be great for a solar panel to help keep batteries charged. |
#48 | |
Active Member
Gonna try and keep the fridge if possible. Trying to leave what was original to a point. Down the road we plan on building a trailer to go along with this. The chalet is great but is lacking for storage for longer than a weekend trip. Not really much will fit in the fridge and there is nowhere to store firewood, cooler, recovery gear ect... LED's are a great idea. I can imagine with all the dark wood and those bulbs it can be a little dim inside.
#49 |
Nice project, looking good....Ripped is not what you want to see when looking at that door, maybe some updated waterproof building materials...Aztec pvc comes in 4'x 8' sheets, 3/8" ...1/2"...as well as 3/4" boards etc ....just a thought...Very cool shop with some interesting displays.....
#50 |
Just read the tread tip to tail. Great looking build! I'll be following along from here on out. I'll be interested to see what you come up with for the trailer. Will it be painted to match?
1980 Chevy K20 "The Wood Truck" |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
