converting 65 c/20 to power disk 71/72
converting 65 c/20 to power disk using 71/72 parts can it be done as far as just dropping the crossmember out of the 71/72 and bolting it into the 65. are the frames the same in the front
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
someone has to know ttt
yep-2wd that is....i have done spindles/lower a frames on a 65 gmc, and the whole crossmember on a 64 gmc.
67-72 parts collector,…
![]() Join Date: Nov 2002
Check Early Classic Enterprises, they have a conversion spindle (c20 to c10) that will let you keep your crossmember, a-arms, etc. Just swap spindles and use half ton rotors and calipers. Not nearly as much work.
thanks guys in the process the truck is going to be converted to 5 lug so the spindles might be the way to go i just wanted to make sure that everything was the same
if you dont already have the stuff i've got all you need out of a '72 chevy. just letting you know in case you need it.
'67 c10 350/th350 |
