03-22-2019, 07:38 PM | #1 |
Break Clevis Pin
Bought a bracket off the forum and need a clevis pin to hook the brake pedal to it. Anyone know what size and length clevis pin is require. Any thought on where to buy one on a weekend?
Also is there a clip required at the notch in the pin the brake booster connects to on the bracket? I bought a brake booster, have the bracket, have brake line and bought brakes hoses and was going to complete my brake system tomorrow.
Stupidity was meant to be painful! |
03-22-2019, 10:37 PM | #2 |
Re: Break Clevis Pin
I have an assortment of pins. You know what size you need?
I'll send one off to ya Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
03-23-2019, 07:14 PM | #3 |
Dog gone dude, I spent HOURS looking for my push rod assembly. Looked everywhere they could possibly be, twice. Then I realized that WHOOPS, the box was two feet from my computer the entire time. Anyway, I gathered up the parts and pictured. Not sure which pin you mean, but here's the set-up:
If you mean the push rod to brake pedal "pin", it's a special bolt.........
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-23-2019 at 07:27 PM. |
03-23-2019, 08:48 PM | #4 | |
I guess I'm missing several parts. I'm missing 1 of the push rod pins and 2 clips, 2 washers and 2 "wave" washers. I'm also missing the brake push rod. I have the part that connects to the pedal, but I'm missing the other end. I have the bolt for the brake pedal although when I took it apart today it did not have a cotter pin. I also noticed the spring it broken. Think I can find something at a local parts store or perhaps a hardware store?
03-23-2019, 11:18 PM | #5 |
Napa should have the wave washers, might even have the pins and clips.
Otherwise it's piece work, Ebay, and our parts board is real good. That or if you're lucky a wrecking yard.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-24-2019, 12:24 AM | #6 |
I had the same question and similar issue a couple of weeks ago, but NAPA was a strike out. You may try eBay or In-line Tube if this is what you are looking for. I got lucky in finding my pin, but the clip itself I got off Amazon. I believe should be the same for GM/Camaro’s.
1971 Custom/10 - 350/3 speed, Orange/White roof |
03-25-2019, 11:16 AM | #7 |
Lol, just noticed "Brake" is misspelled in the topic name. I have to be more careful typing on a phone. DOH!
A trip to Ace Hardware yielded some results. I bought a 3/8" x 2" clevis pin with multiple holes, 3/8" flat washer, cotter pins and a bronze sleeve bearing with a 3/8" inside diameter. I cut the clevis pin down and ground the end down to a bit over 1" long. using a washer and cotter pin it works perfect for the brake booster push rod. Since I did not have the proper end for the push rod and had 2 push rods for manual brakes I cut the bronze sleeve to match the length of one the pedal attachments. The inside of the pedal attachment was still lightly larger than the outside of the sleeve so I put a few rounds of tape around it to snug it up and take up the small amount of slack. Could not find a store opened on the weekend to buy a threaded rod that match the thread of the pedal attachment. Using 2 pedal attachment I'll need a threaded rod about 4 3/4" long to make a brake push rod that will work. My double flare tool broke with 2 fittings to go so I was unable to finish the lines, but I replaced all the lines and hoses to the prop valve. Turned out OK and should suffice until I find all the vehicle correct parts. Hoping all the flares are good and do not leak. Love using the copper lines. The plug to bleed the master is the wrong size, so not sure the best way to bleed it. Ended up buying a master cylinder since the old one showed evidence of having fluid leaking out the back. For the vacuum all I could find was a fuel fitting to fit in the manifold with a 5/16 nipple. Hoping it works and doesn't leak. Thanks for the help.
03-25-2019, 04:03 PM | #8 |
Fastenal had to order the threaded rod. All they could get was a 3'-0 piece. I'll have to cut it down to about 5 1/2". Not going to be in until Wednesday. Bummed I'll be off the road for a few more days.
There is a broken spring hanging off my brake pedal. I'll have to find something somewhere to replace it and find out where it is supposed to attach.
03-25-2019, 04:37 PM | #9 |
I just dealt with the flare tool deal. I bought an unused Imperial Eastman off ebay for $25 delivered. It didn't have any of the dies but inline tube sells them in whatever size you need. The old "performance tool" could never make a good flare. This Imperial Eastman is so easy to use it is ridiculous.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
03-26-2019, 09:40 AM | #10 | |
The auto parts store had a loaner. When I got it it was missing the 3/16 double flare adapter so I'll have to find a different store with them to finish it off.
