Old 03-24-2019, 08:04 PM   #1
cgster
72 Gas Tank
I need to order a new gas tank for my 72 truck because its been sitting for years. What all do I need to order besides the gas tank? A sending unit? I know 72 gas tanks are a little different than the 67-71, so I want to make sure I order the correct stuff. Thanks.
cgster is offline   Reply With Quote
Old 03-25-2019, 01:41 AM   #2
PepperTreeGarage
PepperTreeGarage's Avatar
Re: 72 Gas Tank
You didn't state C10 or C20. There is a difference in the tanks.
PepperTreeGarage is offline   Reply With Quote
Old 03-25-2019, 06:22 AM   #3
cgster
Re: 72 Gas Tank
It's a C10
Old 03-25-2019, 08:01 AM   #4
Redneck Rydes
Redneck Rydes's Avatar
Re: 72 Gas Tank
If you are going to spend the time to chanke the tank,put in a new sending unit also a new neck grommet
Redneck Rydes is offline   Reply With Quote
Old 05-18-2019, 05:06 PM   #5
External
External's Avatar
Re: 72 Gas Tank
Tank. Sending unit. Grommet. All new lines.
The old lines rust on the inside.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old 05-18-2019, 09:59 PM   #6
MeanGreen72C10
Active Member
MeanGreen72C10's Avatar
Re: 72 Gas Tank
sucks I have an original 72 tank sitting here I just took out of my truck.
MeanGreen72C10 is offline   Reply With Quote
Old 05-18-2019, 11:08 PM   #7
External
External's Avatar
Re: 72 Gas Tank
Ok, so I tried doing my research.
Specter from rockauto is best repop tank. According to this site.
Still a debate on EEC or not. Gas smell maybe possible if you dont hook up vacuum can.
Get new line set somewhere. Don't matter. They all come with one piece that doesn't match up.
It sounds kinda easy. I just hope it gets done right the first time.
Fuel system seems to be finicky. It has to be done just right it seems
Does anyone have some more suggestions?
Old 05-19-2019, 12:44 AM   #8
MeanGreen72C10
Active Member
Re: 72 Gas Tank
Im using a blazer tank from a late 80s EFI blazer with pump in tank. going to cut a hole in side of my bed for filler neck/cover
Old 05-19-2019, 02:07 AM   #9
Mbeef61
Mbeef61's Avatar
Re: 72 Gas Tank
Any thought about relocating the tank to the bed? I went with a Boyd’s welding tank and couldn’t be happier.
Mbeef61 is offline   Reply With Quote
