Old 12-04-2016, 10:37 PM   #51
rusty76
rusty76's Avatar
Re: Farm Fresh Silverado
Awesome
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-01-2017, 11:20 AM   #52
made2drag
made2drag's Avatar
in one of the pics it looks like youre riding bumpstops in front. Have you chopped them down or are you leaving them in ?
made2drag is offline   Reply With Quote
Old 01-01-2017, 11:29 AM   #53
made2drag
made2drag's Avatar
"Got an alignment and the tires balanced, but I think it needs new tires, something is still shaking. "
Could be the pinion angle where the driveshaft meets the rearend. If it is smooth until like 45-55 mph than I have found that the pinion angle is slightly off and you can buy shims at an auto parts store to shim and correct the angle. 2 degrees will make a difference. If your tires are not the problem, try the shims.
the truck looks awesome with that stance!
Old 10-07-2017, 05:44 PM   #54
Red Beard
Red Beard's Avatar
I've left them in. It doesn't ride too harsh, and I'm worried if I remove them I'll have even more rubbing issues. I'm been thinking about bagging it.
Thank you. It would shake before I lowered it, so I don't think that is the problem.
1987 R10 Silverado "Farm Fresh" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=703698
Red Beard is offline   Reply With Quote
Old 10-07-2017, 05:46 PM   #55
Red Beard
Red Beard's Avatar
Here's a couple of more recent pictures.
Old 04-01-2018, 11:07 PM   #56
Red Beard
Red Beard's Avatar
I just got my Ingenuity Fab and Speed tranny cross member! Super excited.
Also got my windshield and solid back glass installed.
Old 04-02-2018, 04:37 PM   #57
rusty76
rusty76's Avatar
I like the tranny cross member. That’s pretty darn nice. I’ll need to look into one of those in the foreseeable future.
My build thread
Crossmembers CC
Old 04-03-2018, 08:15 AM   #58
Rich84
Rich84's Avatar
Nice truck..Along for the ride
Rich84 is offline   Reply With Quote
Old 04-03-2018, 10:59 PM   #59
Red Beard
Red Beard's Avatar
Thanks!
It’s good quality! I’m a welder by trade and I have no issues with it. I wish I had the tools at home to build the stuff myself!
Old 04-03-2018, 11:41 PM   #60
Dads79GMC
Dads79GMC's Avatar
Red Beard, I love the stance!!
Looks like you're running 8" rally's with 235/75 tires? If so, any rubbing issues with tires. I saw the issue with the wheel and lower control arm.
Thanks Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 04-04-2018, 01:50 PM   #61
Red Beard
Red Beard's Avatar
Thanks Mike
Yeah it actually rubs pretty bad in the front. Parking lots are a pain. Bags are the plan right now.
Old 04-04-2018, 01:58 PM   #62
Dads79GMC
Dads79GMC's Avatar
Thanks Red Beard
Old 04-08-2018, 08:54 PM   #63
Red Beard
Red Beard's Avatar
Finally fixed my sagging headliner.. WITH SUEDE! FANCY! Haha. I picked up this material back in October and finally got around to it, while I had everything out doing the glass. Also, picked up one of those fancy clear dome light lenses and LED bulb from LMC, because the original stuff was all melted.
Old 04-08-2018, 09:03 PM   #64
Dads79GMC
Dads79GMC's Avatar
Suede fancy!
What did you use for adhesive? I have some perforated, foam backed vinyl to install on an ABS plastic headliner. Thanks Mike
Old 04-08-2018, 09:05 PM   #65
Red Beard
Red Beard's Avatar
Suede fancy!
I used 3M Super 77 spray adhesive.
Old 04-08-2018, 09:08 PM   #66
Dads79GMC
Dads79GMC's Avatar
Excellent! Thanks
Old 04-09-2018, 12:33 AM   #67
StorminNorman
Dang. That lowered longbox looks like a cruise missile sittin there. Nice
81 short step.
StorminNorman is offline   Reply With Quote
Old 04-14-2018, 10:26 PM   #68
LT7A
Good progress man. You're killing me though that the front suspension now consists of compression of the bump stop. You could just pull the springs out and set them aside to save weight, haha. I like how the truck sits but I don't think it would look bad at all if you went back up an inch in front and two in the rear. But you said you are thinking about bagging it, so if going low is the point then the rubbing and bumping is part of the game. That wasn't supposed to sound dirty BTW, ha. Anyway, nice work, I've always liked this color combo.
Old 03-25-2019, 03:18 PM   #69
Red Beard
Red Beard's Avatar
The issue I'm running into now is the carrier bearing in now lower than both my transmission and my axle and causing some weird angles. I don't know whether to raise the carrier or switch to a one-piece driveshaft.
Old 03-25-2019, 06:17 PM   #70
ShortHaul
ShortHaul's Avatar
Re: 1987 R10 Silverado
Originally Posted by Red Beard View Post
I had it in my old 83 Malibu wagon lowrider back in high school, too.
I'm just here for pics of the Malibu wagon lowrider...
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 03-31-2019, 11:50 AM   #71
82Diesel
Nice truck... well it was until you lowered it :/
Hard to find these days with Electric Doors Boy I'd would of kept it as is.
1979 Pontiac LeMans 231/Th350
1982 Chevrolet Silverado K10 6.2 Diesel/700r4
1984 Buick Regal Limited Sedan 4.3 V6 Diesel/200r4 (Hens teeth rare)
1991 Chevrolet Silverado K2500 5.7/700r4
1999 Chevrolet Base LS K2500 6.5TD/4L80e
82Diesel is offline   Reply With Quote
Old 04-20-2019, 11:15 AM   #72
Red Beard
Red Beard's Avatar
Here you go.
Old 04-20-2019, 11:16 AM   #73
Red Beard
Red Beard's Avatar
Well that's not any fun, now is it?
Old 04-20-2019, 02:10 PM   #74
LT7A
Well-handled.
Old 04-24-2019, 12:28 AM   #75
Tsoptich83
Tsoptich83's Avatar
Nice long bed. Stance is exactly what I'm looking for. Did you change out the drive shaft or raise the carrier support?
Thomas
Retired Marine, OIF & OEF Vet.
My Project: http://67-72chevytrucks.com/vboard/s...d.php?t=771429
Tsoptich83 is offline   Reply With Quote
