Old 03-27-2019, 01:01 PM   #1
Mbeef61
Mbeef61's Avatar
Trying to figure out how my truck was lowered, spindles or cut springs...
New to me 1971 c10 2wd. It’s lowered. I was told it was with drop spindles but I am thinking not. Spindles look stock to me. Can anyone confirm?
Look at how close the bump stop is. That doesn’t seem right. Does it look like they just cut the springs? Wheels/tires have no horrible camber but there are a lot of shims.
I like the stance it has. Can anyone estimate the drop? I will post tire size here shortly if that helps.
Rear springs look aftermarket. They are blue.
Mbeef61 is offline   Reply With Quote
Old 03-27-2019, 01:02 PM   #2
Mbeef61
Mbeef61's Avatar
Re: Trying to figure out how my truck was lowered, spindles or cut springs...
Pics
Old 03-27-2019, 01:12 PM   #3
Mbeef61
Mbeef61's Avatar
More pics. Sorry some are sideways?
Old 03-27-2019, 01:15 PM   #4
Mbeef61
Mbeef61's Avatar
One more
Old 03-27-2019, 01:50 PM   #5
68Stepbed
68Stepbed's Avatar
Definitely stock spindles. The front springs may have had a coil cut off, but they don't have the typical warping that happens when the springs are heated.
The rear spring "could" be a 4" drop, but hard to say for sure. Clean them with soapy water and see if there's any brand names or part numbers still on them.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-27-2019, 01:53 PM   #6
Mbeef61
Mbeef61's Avatar
Thanks for the reply. I am a “do it right” kind of guy. Any idea what drop spindles I would need to keep the front about the same level? The bump stop is so close there is little to no suspension travel. I am going to spruce up the brakes with new calipers, rotors, and add power master cylinder.
Old 03-27-2019, 03:07 PM   #7
bs46488
I just installed drop spindles from ECE and are very happy with them.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 03-27-2019, 03:09 PM   #8
Mbeef61
Mbeef61's Avatar
The 2.5 drop? Use stock springs? Have a picture by chance?
Old 03-27-2019, 07:59 PM   #9
Mbeef61
Mbeef61's Avatar
would this kit work by chance? I am wanted to convert to rear disc, and power brakes, I also need drop spindles and I wanted new front calipers and rotors, and brake lines. It is listed up to 1970, could it work with a 71?
https://www.performanceonline.com/19...sion-GM-Truck/
Old 03-28-2019, 11:13 AM   #10
68Stepbed
68Stepbed's Avatar
No. That's for 67-70 trucks. Also, your truck already has the same brakes up front, just with plain rotors. Keep in mind that drilled and slotted rotors don't really make braking any better, so don't fall for that gimmick. Now, if you're racing, slotted rotors add a benefit of expelling trapped gasses and dust created under heavy braking situations, but drilled rotors only look cool.
For suspension needs, I only trust ECE.
Here's the link to the spindles. -->https://www.earlyclassic.com/node/1154
Stock height springs. --> https://www.earlyclassic.com/node/650
If you want a rear disc conversion, this would be a good conversion. https://www.performanceonline.com/71...it-rear-5-lug/
Matt
Old 03-28-2019, 11:23 AM   #11
Mbeef61
Mbeef61's Avatar
I wasn’t going to get the drilled and slotted that is and extra. You can get plain. I need rotors and calipers anyways. Mine are shot. But looking further it looks like 63-70 spindles are different. I wonder why they don’t make the same package deal in 71-72
Old 03-28-2019, 11:51 AM   #12
68Stepbed
68Stepbed's Avatar
Because you can just pick up rotors and calipers at your local parts store or from RockAuto.
Matt
Old 04-01-2019, 02:22 PM   #13
bs46488
Sorry for the delay. Here is a pic of my truck right after the 1.5" spring and 2.5" drop spindle install. After driving around town it settled another inch or so.
