![]() Join Date: Jan 2010
Has anyone cut the lens off from a sealed beam headlight?
I had a brain fart this morning. I ordered new led headlights for my 67 and got the classic look lens. It looks great but I wondered if you could cut the front lens off of a original t3 headlight and use it on my T4 bulb back housing ? How would you cut the sealed beam in half? Diamond bit?
Who Changed This?
![]() Join Date: Jan 2013
Re: Has anyone cut the lens off from a sealed beam headlight?
I know a guy who tried it for some reason or other back in '77. A lot of busted bulbs is all he got for his troubles. I think that the type of glass eventually cracks when it is nicked right, like safety glass does.
![]() Join Date: Jan 2001
It's annealed glass, so you could cut it in theory. It would be pretty difficult. If you used a fine diamond blade and a lubricant like water to keep the glass cool you might be successful. Aside from keeping a straight cut, the biggest problem I can see is the heat resulting from cutting and the temperature differential that would create. That's what's going to cause the glass to break.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
I saw a video somewhere where someone took a piece of string soaked in alcohol wrapped it around a bottle of jack lit the string for a few seconds then droped it in watter and it split where the string was burning . dont know if it really works but might be worth a try
I found this thread from hotrod magazine. I want to do this now. https://www.hotrod.com/articles/1006...rs-conversion/
20' Daredevil (Ret)
![]() Join Date: May 2003
Looks like an interesting project with a chance of shattering some glass as noted above. Depending on your desired result, consider this: The beam pattern is determined by the bulb, the reflector, and the lens. The T3 lens fluting is different than the fluting on an E-code H4 headlamp, so the beam pattern will be altered. No telling what the end result will be. If you go ahead with this, will you post before & after pics? Good luck, it'll be interesting to see how it turns out!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
I agree, the lens is made for the lights to work properly and with that being said I probably won't do this but it would be cool on my truck because I have such a stock looking truck with no modern upgrades appearance wise these will stand out a bit and if the t3 lens was on the H4 case it would still be stock appearance.
![]() Join Date: Oct 2018
That is a good thread. My truck still has both t3 headlights in it. I have not drove it at night but I did have it in the driveway at night with the headlights on and they are very yellow and dim compared to my 2006 truck. I want to leave the t3’s in for the original look but I know I will be driving this at night and it will not be good visibility. Wish they made a t3 upgrade.
20' Daredevil (Ret)
If you haven't already done the relay mod, it's worthwhile. Full voltage to the headlamps makes them brighter. Add some good E-codes like Cibies and you'll have excellent safe lighting for those night drives.
![]() Join Date: Feb 2002
I had a pair of 7'' halogen headlamps, I left on a '67 Suburban for years. When I took them off, the lenses came right off. They were originally epoxied on I guess.
For my purpose, I glued them back together with Blue RTV [what I had around]. I used one for a week until new headlamps came in from RockAuto. The other fell off my tailgate and broke. I think they were Sylvania. Look at the edge. If it's not a solid glass piece, it may separate easily. The Tungsten lamps are sealed, and if air gets into the ''capsule'' the filament burns out quick. But halogens had a small quartz-halogen capsule inside the reflector housing that is self-contained. Of course, it won't say T-3 on the outside.
#11 | |
![]() Join Date: Aug 2004
Chewey; what lights are those?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
They are from octane lighting. They are super nice with the LED's. Much brighter than sealed beams.
Who Changed This?
I second this. The relay mod made a much bigger difference than I expected. $30 well spent.
#15 |
Well I'm going to give this a shot hopefully over the Xmas break. I ordered some diamond wheels today and I think I know how I'm going to cut them to Get a straight cut. I'll post here when I do this and we'll see how it goes.
#16 |
![]() Join Date: Aug 2019
I would try to cut it with a tile saw.
#17 |
![]() Join Date: Nov 2019
Subscribed, I want to see how this goes
#18 |
Try Googleing hid conversion those guys split open many types of headlights by putting them in the oven warm up the glue that hold the lens on and separate them
#19 |
I Wil post the results. I will try it on a different bulb first. I may try a few ideas. I just hope something will work. If you have any links to videos or such where ppl have split these bulbs please post them.
#20 |
At the body shop.
My ancient Cibie lights fell apart.
Replaced with some Hella H4 and a relay harness way better light output
" That didnt make it any newer " " Dont antique the equipment " |
#21 |
Subscribed
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#22 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Subbed to watch too.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#23 |
![]() Join Date: Jun 2007
Also subscribed
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#24 |
![]() Join Date: Aug 2014
What is the relay harness mentioned by a few fellows?
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
#25 |
Who Changed This?
You connect the relays to the battery and the headlights. When you turn on the headlights, power goes through the relays to the headlights instead of roundy-round from the battery to the headlight switch, dimmer switch and then to the headlights. Much less voltage drop. Here is a thread I made to show the difference from stock to using the relays. I bought them from LMC.
http://67-72chevytrucks.com/vboard/s...d.php?t=782071
