Old 03-29-2019, 01:42 PM   #1
michael bustamante
michael bustamante's Avatar
testing a tach
when testing factory tach, do I need to ground it at the tin or behind the guage itself or can I just run a live to the battery and the coil to the HEI?
1967custom
michael bustamante is offline   Reply With Quote
Old 03-29-2019, 03:25 PM   #2
Coley
Coley's Avatar
Re: testing a tach
When I test a tach I (temporarily) wire it this way:
1) Grounded alligator clamp to the tin or tach casing (same thing). (use a good alligator clip or equivalent)
2) (-) terminal/spade & wire to the coil (-) connection
3) (+) terminal/spade & wire to the battery (+)
...either way, you will have to ground that tach housing or you won't get any action on the tach.
After that, I fire the engine and check the tach and ideally use a different separate tach to check the accuracy....which often isn't all that great compared to a digital tach.
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 04-05-2019, 12:16 PM   #3
michael bustamante
Re: testing a tach
great man thank you very much!!
1967custom
