Old 03-31-2019, 04:50 PM   #1
parb
steering wheel... Again!
when i got my jimmy it had an aftermarket steering wheel.
I never liked that steering wheel and after hearing many reviews i ended up buying a comfort grip steering wheel.
while that wheel isn't terrible, see picture, i just don't think it looks right. I'm now thinking that i should go for an truly original look.
Does anyone have a picture of a stock 72 GMC steering wheel i can see?
Does anyone know of a place where i can buy a good quality reproduction steering wheel?
parb is offline   Reply With Quote
Old 03-31-2019, 05:01 PM   #2
CG
BlahBlahBlah
Re: steering wheel... Again!
Interesting, it sure looks good in my eyes.
Old 03-31-2019, 05:05 PM   #3
parb
It looks good in the picture, but i think i should go for the more original big wheel look (17" wheel). I have done so much to keep it bone stock that this seems like it would be a mistake. Maybe i will change my mind (again) but i'm trying to stay as close to stock as i can.
Old 03-31-2019, 05:12 PM   #4
CG
BlahBlahBlah
Ok now I understand and agree. I just looked at your build, I hadn't seen it before. Love the color ... Your doing an excellent job!
Old 03-31-2019, 06:58 PM   #5
BIG BLOCK JIMMY
BIG BLOCK JIMMY's Avatar
That's a good looking steering wheel. I might hurt some feelings, but the OEM ones I have seen are UGLY.
Beautiful interior and perfect color, by the way. Do you have a link to your build?
72' JIMMY 454
BIG BLOCK JIMMY is offline   Reply With Quote
Old 03-31-2019, 07:01 PM   #6
parb
when i got the truck it had an awful aftermarket steering wheel. i think the horncap said "Rally" on it. It was fugly...!
so i got this steering wheel after looking at dozens in catalogs. To be fair, i'm not super unhappy with this steering wheel, but given how closely i've been trying to stay with original i'm now starting to doubt if i shouldn't go back to one of those 17" wheels...
my build thread is here: http://67-72chevytrucks.com/vboard/s...d.php?t=759763
Old 03-31-2019, 07:38 PM   #7
BIG BLOCK JIMMY
Outstanding transformation. I still think your current steering wheel is classic and clean and doesn't detract from the originality of the build. It compliments the Jimmy's subtle unique personality like the LED brake lights.
I've been looking for a steering wheel that my wife and I like. I think you found it. Where did you get that one?
72' JIMMY 454
Old 03-31-2019, 07:59 PM   #8
parb
I got the wheel off ebay. you can find it here: https://www.ebay.com/itm/261375860888
the wheel is plenty nice, feel real good and i'm happy about the center cap as well.
i decided to go with LED early on in the build, for all lights except the headlights. I wanted to make sure I was plenty visible and i personally think the old incandescent bulbs are hard to see. i choose to keep the headlights stock, altough if i would have found an exact LED replica i may have changed those too. In the dash i went incandescent as well as under the dash. It was easiest at the time to stick to incandescent there.
Old 04-01-2019, 01:27 PM   #9
Blazerowner
Blazerowner's Avatar
The only issue I have with the older wheels is they feel like a tractor when you turn because they are so large. I like the current wheel as well but if you don’t like it swap it out for an original. You can always switch back and forth for driving and show.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 10-18-2019, 12:46 PM   #10
Tommyups
I like your comfort grip steering wheel on your Jimmy! Was that just bolt on or did you need an adapter kit? I have a 67 that I’d like to use that wheel on
Tommyups is offline   Reply With Quote
Old 10-18-2019, 01:49 PM   #11
A1971Blazer
A1971Blazer's Avatar
Although not original..they are period correct...I like
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 10-19-2019, 02:51 AM   #12
parb
I've grown to really like that steering wheel. I think it will stay on for a bit longer!
Old 10-19-2019, 08:45 PM   #13
simicrintz
I like that steering wheel as well. And the seats, and the center console, and the AC......
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 10-20-2019, 08:31 AM   #14
BIG BLOCK JIMMY
As previously stated I like that steering wheel. I've been looking for a year and that one is the winner. Can anyone tell me if it's made in the USA or China? I couldn't find it on the Ebay page.
72' JIMMY 454
Old 10-20-2019, 12:24 PM   #15
parb
I didn't keep the packaging do I don't know. Send the seller a message and ask?
When in doubt I assume China.
Old 10-20-2019, 05:26 PM   #16
litebulblsc
litebulblsc's Avatar
I am pretty sure it is a Grant steering wheel. And I am pretty sure they are not made in America
litebulblsc is offline   Reply With Quote
Old 10-20-2019, 05:41 PM   #17
BIG BLOCK JIMMY
I'm sure you're correct. If it was made in the US it would cost twice as much.
72' JIMMY 454
Old 10-22-2019, 07:42 AM   #18
Mike C
Mike C's Avatar
The wheel in A1971Balzers post, #11 is the GM comfort grip wheel. The OP’s wheel is aftermarket. Looks nice though.
I am a big fan of the comfort grip wheel as it uses no adapters and fits and looks right for the era because it is a factory wheel even if not optional in the truck. They can be had for about $200 complete. Buy one for a 1967-68 Camaro as it has the smaller diameter steering column that is same diameter as the truck column.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-22-2019, 08:35 AM   #19
throttlesteer
67-72 Vette wheel with a Camaro hub. Bolts right in looks great.
throttlesteer is offline   Reply With Quote
Old 10-22-2019, 11:09 PM   #20
Subdude59
Active Member
Attachment 1950694
That is a steering nice wheel. What did it come stock on again? My 71 is the same color as yours. Where’s you rear view mirror? Thx
Subdude59 is offline   Reply With Quote
Old 10-23-2019, 07:06 AM   #21
A1971Blazer
It was listed for a '69 Camaro...it came with the hub, horn button, and all the necessary hardware to install...
I have a rear view mirror now...I had to go through a couple of different reproduction ones to get one I liked.....
1967 C10 Step side
1968 C10 Step side
Old 10-28-2019, 07:32 AM   #22
Mike C
Mike C's Avatar
In 69 the column got slightly larger in diameter in the Camaro because of the steering wheel lock that was installed with the ignition on the column.
The 67-68 Camaro adapter is the same diameter as the 67-72 truck column for anybody ordering.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-28-2019, 08:01 AM   #23
notsolo
notsolo's Avatar
This was in my 71Chevy, maybe someone knows what years came with the hard plastic, or this kind with softer rubber, maybe 73 and up.
notsolo is offline   Reply With Quote
Old 10-28-2019, 08:08 AM   #24
A1971Blazer
Good point.....When I ordered the steering wheel and mounting kit....the steering wheel was standard..... but I had to specify the diameter of the hub I needed....which of course is the smaller one...
1967 C10 Step side
1968 C10 Step side
Old 11-06-2019, 08:46 PM   #25
BIG BLOCK JIMMY
I just received mine from Brothers. I couldn't install a new steering column and put the same old wheel on....
72' JIMMY 454
