04-01-2019, 08:45 AM | #1 |
column shifter lever
The column shifter lever is all floppy on my 82 making it were it's getting unsafe to be sure it's in park
Is it spring loaded or ??? Anyone done a fix for this ???? |
04-01-2019, 05:08 PM | #2 |
Re: column shifter lever
Here is all the parts.
Some of the small parts are hard to find now days
04-01-2019, 07:01 PM | #3 |
There's a bunch of numbers there but it doesn't tell me what they are !!!!
04-01-2019, 08:03 PM | #4 |
Sorry forgot this. It does not list the actual parts numbers and I don't have that catalog to cross reference.
Normally from what you are describing, the spring or bushing (#6, 7, & 8) in view B are what is messed up or missing. You might find the bushings ( Genuine GM 1377083 Control Linkage Insulator/Bushing) on e-bay, but a lot of folks ask way too much for them since they are no longer produced. This is where I got mine. https://www.ebay.com/itm/New-Genuine...item2a3940c649 I just found a spring in the hardware store and used it to replace mine.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 04-01-2019 at 08:11 PM. |
04-02-2019, 05:32 AM | #5 |
It is not listed in the break down above but there is a small spring under the (20) shifter lever end in the steering column bowl. that will often break causing the shifter to not spring back towards the dash.
once you drive the pin (18) out and remove the lever, you should be able to dig it out with a small pick. make sure you get all the pieces out or the new spring will not fit.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
04-02-2019, 05:35 AM | #6 |
Old Heap Driver
I would begin by checking numbers 3, 4, 13, 14, 15, and 17 from the illustration to see if those areas are tight. Bushings in those areas could be worn out or missing causing the feeling you're describing.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
04-02-2019, 07:41 AM | #7 | |
Now to find a spring Thanks |
