#476 |
![]() ![]() Join Date: May 2015
Re: Columbus..the 1957 IH 4x4..
and I got the gas pedal installed..i had to modify the bracket a little...
I bent the lower portion at a angle to fit the toe board...and straightened the pedal offset some to clear the trans hump..it fits good and works...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 10-14-2019 at 10:21 PM. |
#477 |
Pretty nice!!
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
#478 |
thanks Mike..
#479 |
Back on my door hinges...
I had noticed some considerable wear on the catch that holds the door open..they were worn bad...so I built them up with weld and just had to guess what they used to look like and ground a new profile on them...I also realized there used to be a roller on the pins....one pin still had a tiny piece of roller jammed under it so it gave me something to go on...I machined a new set from some stainless and reassembled to check fit...the springs arnt on at the moment...still want to work on the roller pockets a little bit..then I'll resandblast em and lay another coat of epoxy on em and I'll call em done...
#480 |
![]() Join Date: Apr 2008
As usual, nice work. They should operate like new!
#481 |
![]() Join Date: Jul 2012
Impressive work Greg!
#482 |
Nicely done!
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
#483 |
Looks great, I really like a simple classic looking interior in these old trucks. You should definitely be proud of that truck!
My 57 GMC build |
#484 |
thanks Tigger,Doug,Scott,and old57
its amazing at how simple things were back then..probably less than 10ft of wiring under the dash...just enough stuff to make it work...
#485 |
Well I finally got some time away from work..so I spent the day trying to make some progress...installed the new 4.56s in the front....I think I'm gonna quit right here with the pattern...1st pic is drive side...2nd pic is coast side..I've got 19in/lb pinion rotation and .010 backlash....since the.front will be rarely used I'm good with it...now on to the rear..
#486 |
Getting ready to setup the rear gears and locker...I knew from welding the new spring perches and shock brackets on the 14b that some warping probably took place ...so I machined a set of fake bearings and stuck them in the diff...a stick of 1-1/2" ss inserted in the housing tells the tale....the pass side if off just a tick ..but the drivers side is off very bad...I still need to machine the outer bushings to know 100% for sure what needs done...
Anybody reading this please take notice..when you weld brackets and whatnot on a axle tube ,it will warp,and needs straightened ...not fixing this will lead to exsissve wear of parts.. 1st pic is center bushings 2nd pic is pass side 3rd pic is drivers side..
#487 |
![]() Join Date: Jul 2009
That's a slick idea on how to check the tubes. I wouldn't have thought to do that.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
#488 |
How will you fix it?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#489 |
thanks Rgun....back when I drag raced and we narrowed rear axles we used this method...doing this has been around for a long time...
Zepp, im going to use acetylene torch to heat the axle tube...ill start in a small spot and quench with water rag...you actually heat it on the side it needs to go...when you heat it itll go the other direction ,and then pull back past where it was...that's the 1st method ill use...as bad as it is I may have to use a press to get it close... the red arrow shows where on the tube ill heat between spring pad and diff housing...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 04-29-2019 at 07:47 PM. |
#490 |
heres a couple short videos of the process...
https://www.youtube.com/watch?v=gqT0hWfXbVg https://www.youtube.com/watch?v=X8m919bCeEE
#491 |
got my outer bushing made this afternoon and did a test fit..
luckily the pass side will need nothing done to it drivers side is a different story...as you can see in the pic. I made my bushing dual purpose..one side is for test fitting tube straightness,and the smaller side I machined to fit inside the outer axle bearing so I can use it to seat the bearing in when the time comes pic 1 is bushing pic2 is pass side with bushing slid into axle tube pic3 is drivers side to show how far off it is pic4 is where I heated the axle to make it draw..i only heated it to a cherry red color.i decided to let it air cool instead of using a water quench ...ill let it cool overnight and see where it is in the morning
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-03-2019 at 04:14 PM. |
#492 |
Well I had to do 5 heat soaks on the tube to get it where it belongs...I expanded my heat zone from around 2in to about 5in...and let it completely cool between each heat cycle
And heres the results... I'm gonna roll with this... Before and after pics
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-02-2019 at 05:39 PM. |
#493 |
That turned out great! Nice work! Thingsll go together much better now.
#494 |
Thanks Scott !.....
Thingsll.....I saw that...haha
#495 |
Nice job straightening the housing!
Robert |
#496 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Been following in the shadows for a while but must say it is coming along nicely
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#497 |
Greg that was some nice work on the housing. I learned something there. Thank you for sharing.
#498 |
Great work Greg!
#499 |
thanks Robert,Richard Doug and Mike..!!!!!...positive comments always mean alot
#500 |
I know the pieces fit
I've been following this one too. Love an old IH. Great work.
