Old 05-29-2004, 09:38 PM   #1
406cid70Chevy
charging system question
My truck drains the battery when it's running. So I checked the battery with a multimeter, it's at 12.8 volts with the engine off. With the engine on it's at 12.6 volts. Shouldn't it be at about 14.2 volts when the engine is running? I have the old style externally regulated alternator. Are there any tests I can perform to determine if it's the alternator, voltage regulator, or another source? Could bad grounds cause this? Thanks!
406cid70Chevy is offline   Reply With Quote
Old 05-29-2004, 09:57 PM   #2
Jeepster376
Jeepster376's Avatar
Yup
If you know how to energize the field on your alternator, you can eliminate the regulator to determine if it's bad. Otherwise you could just bring the alternator into an auto parts store and have it tested.
Check that your regulator is well grounded to the core support. The alternator is grounded directly to the block through the mounting bracket, and your battery ground cable should also be direct to the block. The block should also be grounded to the firewall.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 05-29-2004, 10:01 PM   #3
jef5150
Inline 69
jef5150's Avatar
try this, it only takes 2 minutes,,pull a cable off the battery while its running,if it dies, its a 99.8% chance the alternator is bad. its easier if you loosen the cable clamp before you start it,,,, then you can start checking other things (dont do this on newer vehicles with ob computors) jeff
jef5150 is offline   Reply With Quote
Old 05-29-2004, 10:11 PM   #4
Baradium
Binder Rep
Baradium's Avatar
with lower voltage with the engine on, you already know the alternator isn't charging at all.
Voltage should be 13-15 volts with the engine running. Careful with bypassing stuff, don't want to burn up anything.
Baradium is offline   Reply With Quote
Old 05-29-2004, 10:55 PM   #5
406cid70Chevy
I went and got the alternator tested at autozone, it was putting out 250amps...pinned the needle. The guy didn't know what that meant, he just said it's not right. The alternator can't really put out that many amps can it?
Old 05-29-2004, 11:05 PM   #6
Jeepster376
Not for very long.
He probably didn't test it properly as externally regulated. It's your regulators job to control the alt output. Sounds like your alt works OK.
Old 05-29-2004, 11:19 PM   #7
GSFMECH
On the road
GSFMECH's Avatar
I agree with Jeepster, sounds like the alternator is ok. I would pull the cover on the regulator and check the points and inspect the coils. Sometimes you can spot a problem with the coils such as overheating etc. and see if the points are pitted or carboned up. You can clean them with a points file but they never last long after you knock the factory edge off them. I would just replace the regulator if it were me as it is more than likely almost 35 years old anyway.
Mike
GSFMECH is offline   Reply With Quote
Old 05-29-2004, 11:27 PM   #8
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
I think the guy doesn't know what he's doing. All the alternator bench testers I've seen cannot check the current output, just the voltage. We don't have Autozone here, but if its anything like Schucks, the people there don't know squat. They only know what the computer tells them. 250 amps would fry your wires.
Cat Fuzz is offline   Reply With Quote
Old 05-30-2004, 03:39 AM   #9
1972C10
1972C10's Avatar
yeah 250 amps out of a delco alt is impossible well maybe not but very hard
Its hard to get 200 amps out of a big leece neville train alternator
And if you need a reg ive got one that was on the truck for a week then i went to an int reg alt ,
1972C10 is offline   Reply With Quote
Old 05-30-2004, 01:36 PM   #10
406cid70Chevy
Well I took the alternator to another parts store and it tested out ok. It's supposed to put out 14.4 volts right?
So I bought a voltage regulator there and when I got home I popped the cap off the old voltage reg. and found a blown/fried wire. Well that was at least part of my problem, because it still doesn't charge at 14.4 volts. I let it warm up and revved it a bit and it got up to 13.8 volts on the revs, but then would drop down to about 13 volts at idle. What does this mean?
To double-check I tested my car at idle, it was at 14.4 volts.
Another question, what is the purpose of this resistor? that plugs into the volt. reg. in the pic?
Thanks for all your help guys I appreciate it.
Old 05-30-2004, 03:48 PM   #11
1972C10
1972C10's Avatar
I never could get over 13 volts out of mine thus the reason i went to internal reg.
Old 05-30-2004, 08:46 PM   #12
Jeepster376
You should get ~14.4v at the stud on the back of the alternator, and 13.8V at the battery. Sounds like you're right on the money.
Old 05-30-2004, 08:53 PM   #13
406cid70Chevy
So the voltage is not supposed to stay constant then? It's supposed to fluctuate with engine rpm?
Old 05-30-2004, 09:14 PM   #14
Jeepster376
That's normal, as the alternator does not work to it's fullest at idle RPMs.
Old 05-30-2004, 11:46 PM   #15
'68OrangeSunshine
'68OrangeSunshine's Avatar
That's not a resistor, it's a capacitor. It's not normal [stock], there should only be a ground lead off your front engine/headlamp harness with a self-tapping screw to ground the side of the regulator box to the system. Best guess is that capacitor was for Hi-Fi or CB noise reduction. If you didn't install it yourself -- you probably don't need it. A capacitor doesn't flow current constantly, it stores it up then bursts it thru at intervals. That could be your gripe right there.
Old 08-21-2004, 06:49 AM   #16
kbs71
71 rustless in texas
kbs71's Avatar
These old style voltage regulator hardly worked when they were newly designed. Back when these trucks were first manufacture,d. all they were worried about was ignition, lights, a blower motor and maybe a radio. Since then they have added more accessories along with us owner creating a larger draw on the alternator. These newer external volate regulators are produced overseas and are no longer the quality that they once were. Hence they don't work as well. I installed a new altenator (35 amp) and then I went through 4 of them in 3 months along with a battery from the charging system not operating correctly. I bought a internally regulated altenator kit and installed it along with a 96 amp altenator. I also put in headlight relays. I get 14.4 amps out of the altenator all the way to the battery I no longer have weak lights or a weak ignition system. I love the new system. I did not go to a one wire system because I think that is just basically a battery charger and doesn't actually act like a altenator. It only took me about one day some soldering and the trucks charging system is now fantastic.
kbs71 is offline   Reply With Quote
