Old 04-08-2019, 01:03 PM   #1
Bearhawg
Bearhawg's Avatar
Power Steering Pump Seal vs O-ring
I started to rebuild my PS pump and ran into an issue. The seal kit I purchased included o-rings and not the square shouldered seal on the pump. I figured one was as good as the other but soon discovered there is a difference. With the o-ring, I was unable to install the pump tank on the pump. The o-ring would not stay seated in the grove around the pump. I tried it will fluid on the seal but it was still too tight to install the reservoir.
Has anyone done the install with the o-ring? If not, where did you find the correct seal?
Thanks!
Bearhawg is offline   Reply With Quote
Old 04-08-2019, 03:16 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Power Steering Pump Seal vs O-ring
I thought they were all o-ring. The bolt seals are square cut.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-10-2019, 08:23 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Up to 77 the pumps used a square cut seal instead of an O ring...
GM part number is 5688015
Jegs lists the kit under https://www.jegs.com/i/OER/691/12535...SAAEgIRS_D_BwE
Hope this helps...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
