Old 04-13-2019, 05:46 PM   #1
vet57air
vet57air's Avatar
Cgt project
Been here awhile, but recently acquired a truck to start. It will be heavily modified, static drop of about 4" ride height with 22"s. I plan to drive it lots long distance hence the Cgt name. Presently have the sheet metal blasted and epoxy coated. Just received my custom frame from Dale Gerry street rods.
vet57air is offline   Reply With Quote
Old 04-13-2019, 06:59 PM   #2
Ronzo
Ronzo's Avatar
Re: Cgt project
Very nice, more please...
Ronzo is offline   Reply With Quote
Old 04-13-2019, 11:45 PM   #3
Captainfab
60-66 Nut
Re: Cgt project
That frame is a work of art.....very nice. What are your plans for a drivetrain?
Old 04-14-2019, 10:23 AM   #4
vet57air
vet57air's Avatar
Re: Cgt project
Presently planning for LT4 8 spd. auto
Old 04-14-2019, 09:56 PM   #5
Clyde65
Clyde65's Avatar
Re: Cgt project
Lt4? Maybe an LT Gen V? 6.2 or 5.3?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-15-2019, 09:08 PM   #6
vet57air
vet57air's Avatar
Re: Cgt project
LT4 gen 5. The 650HP one.
Old 04-16-2019, 04:25 PM   #7
Clyde65
Clyde65's Avatar
Re: Cgt project
650hp? Wow! Obviously not stock.
Clyde65
Rebuild of Clyde
support our troops!
Old 04-16-2019, 10:23 PM   #8
vet57air
vet57air's Avatar
Re: Cgt project
Stock for Z06 Corvette, ZR1 Camaro or CSV Caddy.
Old 04-21-2019, 12:21 PM   #9
vet57air
vet57air's Avatar
Re: Cgt project
Working on getting all the sheet metal mounted. Mocked up a 28" tall front tire.
It fits, but want a 30". Run out of room in a hurry. Being a static drop much different build than air ride.
Old 04-22-2019, 11:28 AM   #10
Kermitt47
Kermitt47's Avatar
Re: Cgt project
Very nice start. I will be following the Gen V powertrain and it's challenges but for a keeper it should be worth the effort.
Kermitt47 is offline   Reply With Quote
Old 04-23-2019, 11:25 PM   #11
HSRACER
HSRACER's Avatar
Re: Cgt project
Great start, I will be following along.
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 04-24-2019, 01:44 AM   #12
Lokin4AReason
Lokin4AReason's Avatar
Re: Cgt project
Looks like a solid start. Keep those updates coming ....
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 04-24-2019, 01:46 AM   #13
kdad
Re: Cgt project
Wow that frame is beautiful. Straight truck porn right here.. Keep the updates comin
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039
She may not be the prom queen but at least she puts out..
kdad is offline   Reply With Quote
Old 04-28-2019, 05:36 PM   #14
vet57air
vet57air's Avatar
Re: Cgt project
Installed the cowl hood hinges. I want to smooth the firewall, but appears the easiest way to do what I want is to replace the whole thing. There is a structure on the drivers side for the master cylinder and pedals that I would like to keep for strength, but looks like it might give me trouble as the firewall is proud there. Anyone have experience with getting the firewall flat?
Old 04-29-2019, 10:41 AM   #15
SCOTI
SCOTI's Avatar
Re: Cgt project
Following along for the build.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-21-2019, 11:27 AM   #16
vet57air
vet57air's Avatar
Re: Cgt project
Slow going in the summer as I rather ride or drive a Hot Rod. Even so I am slowly progressing with raising the bed. Will be a wood floor with less bolts.
Old 06-21-2019, 10:08 PM   #17
SkinnyG
SkinnyG's Avatar
Re: Cgt project
Watching along intently, as I will be cutting into my '61 soon.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 06-23-2019, 10:36 PM   #18
vet57air
vet57air's Avatar
Re: Cgt project
Fit my new Mar-K tailgate. Uses small bear claw latches to close. Vertical gaps are good and it fits very close to flush with the bed sides. I would like to install some small rubber bumps so that when closed it won't be metal on metal.
Originally with chains holding the tailgate closed, it would rattle around a bit.
There is barely enough room for the tailgate to fit into the box sides. The only way I see to get more room is cutting and welding?
What are guys doing to accomplish this?
Old 06-30-2019, 01:40 PM   #19
vet57air
vet57air's Avatar
Re: Cgt project
Semi Installed some custom inner fenders. Won't bolt up front and rear until I do the firewall.
Old 06-30-2019, 07:49 PM   #20
vet57air
vet57air's Avatar
Re: Cgt project
I plan to modify my Mar-K tailgate. I really like the hidden hinge setup, but I think they forgot to hide the nuts/bolts for the hardware on the sides. As with pretty much everything we do with our trucks, its been done before. "Boosted Bertha" did something which looks more original. "Unruly" did it different. I am leaning to go more like unruly, except make my side pieces sized similar to what the bottom of my tailgate is, what do you think?
Old 06-30-2019, 08:38 PM   #21
SkinnyG
SkinnyG's Avatar
Re: Cgt project
I like your idea - mimic "Unruly", but have the size/angle of the sides match that of the top/bottom.
Old 07-07-2019, 10:27 AM   #22
vet57air
vet57air's Avatar
Re: Cgt project
Much better!
Old 07-24-2019, 11:44 AM   #23
vet57air
vet57air's Avatar
Re: Cgt project
Picking away at the box of the CGT.
Got the tailgate fitting reasonabley
I had a real issue with getting the tailgate fully closed as it was being stopped by the "stake pocket box". The only way I could figure out to fix was to relieve it or cut it. I chose to cut it and kind of like the "line" now. Because I have a raised bed I can install rubber bumpers in my new upper brace for the tailgate to rest against. Still have to slice and hammer the top of the bed sides to get the tailgate gap right.
Old 07-24-2019, 03:31 PM   #24
Android04
Android04's Avatar
Re: Cgt project
Got my full attention. That frame is absolutely beautiful and love the tailgate setup
Android04 is offline   Reply With Quote
Old 08-25-2019, 08:38 PM   #25
vet57air
vet57air's Avatar
Re: Cgt project
Measuring up for rims and tires. I would like 22" x 10" rims on the front. My plywood dummy that size fits but I will have to limit the rack as in the picture that is full turn. Interference comes from tire hitting the sway bar. It turns 30 degrees on the outside tire. About the same as my 34 Ford coupe.
