Old 04-14-2019, 06:41 PM   #1
kingsolver72
10/30/19
kingsolver72's Avatar
31-10.5x15?
I’m needing to replace the tires on my 72 C-10. 235/75/15s. They just look too small in my opinion. For some reason the tires look goofy to me. Would 31-10.5x15 fill the wheel wells more than the current tires I have now. Is a couple of inches going to effect the looks? Is there a better truck tire that fills in more space? Factory height 2 wheel drive. No power steering. Would there be any issues that I would encounter? I’ve searched a bit and not really finding answers.
kingsolver72 is offline   Reply With Quote
Old 04-14-2019, 07:26 PM   #2
Mike C
Mike C's Avatar
Re: 31-10.5x15?
I had 265 75 15 on my short step for awhile. They are almost 31 10.5. They dramatically affect your gear ratio and speedometer compared to the stock approximately 28" tall tires.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-14-2019, 07:42 PM   #3
geezer#99
geezer#99's Avatar
Re: 31-10.5x15?
Since your 235’s are likely already installed on too narrow (wide) of a rim then you’ll need wider rims too.
Old 04-14-2019, 08:40 PM   #4
palallin
Re: 31-10.5x15?
I have run 295-75/R15s on my stock rims for years without any hassles at all. They do a good job of filling the wells, and there is no rub, even at full suspension travel.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 04-14-2019, 08:43 PM   #5
Rooster73
Re: 31-10.5x15?
255 70 15 was a popular swap from 235's in the 90's on c1500, Van's, and suburbans, they were 7 inch wheels.
Rooster73 is offline   Reply With Quote
Old 04-14-2019, 08:56 PM   #6
71gmcC15
71gmcC15's Avatar
Re: 31-10.5x15?
They are closer to a 275 /75 r15 then a 265 75 r15 I plan on running 31×10.5 r15s on 8 in wide rims and I know it will work just fine. I've seen it before. Even on lowered c10s
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 04-14-2019, 09:01 PM   #7
71gmcC15
71gmcC15's Avatar
Re: 31-10.5x15?
Last I knew demian5 run this same size with a 3 inchs drop in front and 4 or 5 in drop in rear
Old 04-14-2019, 09:05 PM   #8
Rick Bollinger
Re: 31-10.5x15?
That's what I have o mine now. Along with a th400 and 3:08 rear wasn't to bad on the highway but hard to do a burnout on a hot day
Rick Bollinger is offline   Reply With Quote
Old 04-14-2019, 11:19 PM   #9
Terrysch
Re: 31-10.5x15?
Also have 31 10.5 15 on my Jimmy.
They look great.
Believe they will do what you want, fill out the wheel well.
My Jimmy has no lift, so should fit your truck.
I can't take credit, the last owner put them on. But glad he did because I like the look with them on my Jimmy.
If you want some pictures, just PM me you email address, and I will take some pics and send to you.
Terry
Terrysch is offline   Reply With Quote
Old 04-15-2019, 12:09 AM   #10
stilldreamin6772
Re: 31-10.5x15?
This is what came on mine when I bought it. They are 31-10.5-15. All stock suspension. Unfortunately I have not drivin the truck as I went straight into a motor swap.
stilldreamin6772 is offline   Reply With Quote
Old 04-15-2019, 07:23 AM   #11
kingsolver72
10/30/19
Re: 31-10.5x15?
Thanks for the input fellas.
Old 04-15-2019, 07:36 AM   #12
Re: 31-10.5x15?
One thing you could do is go to 8" wheels. Since that is the limit on wheel width for that size. That will help 'fill' the wells in one way, just not diameter. If you still want more tire you already have the wider wheels you'd need. With the LT truck sizes, such as 31/10.50, you get into mostly treads looking appropriate for a 4wd. It's nice to run rounded shoulders such as on passenger car size tires. Getting into the 70 series allows some wheel well filling with 255-295s. If you want same size all around you'll probably want 275s for most tire that fits. 255s fit best up front.
Old 04-15-2019, 12:33 PM   #13
garyd1961
Re: 31-10.5x15?
I running 255/ 70/ 15 on 8" rally wheels and they fill in the fenderwells pretty good. I'm also running a 350, th350 trans, and 308 gears with no problem.
garyd1961 is offline   Reply With Quote
Old 04-15-2019, 08:00 PM   #14
6T7 C10
Re: 31-10.5x15?
If you are running the stock 5.5" wide rims you could get by with 30x9.5R/15's. They split the difference between the 235's and the 31's.
6T7 C10 is offline   Reply With Quote
Old 04-15-2019, 10:36 PM   #15
Dr.HairyOlds1966
Re: 31-10.5x15?
Attached is a pic of my 69 custom camper on 31x10.5 R15's
Dr.HairyOlds1966 is offline   Reply With Quote
