Old 04-15-2019, 03:29 PM   #1
BlouDon
BlouDon's Avatar
350: Coolant flow when t/stat closed?
My '70 C10 is not fitted with a cabin heater (yet). Beside hoses from water pump and t/stat cover to radiator, there are no other coolant hoses. 350 SBC (Gen 1 -I think...).
Am I right by saying that there will be zero coolant flow while the t/stat is closed?
If I am wrong, please explain to me what route is available to coolant while the t/stat is closed.
Best regards, Philip
Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp )
Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e
Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12
BlouDon is offline   Reply With Quote
Old 04-15-2019, 05:11 PM   #2
garyd1961
Re: 350: Coolant flow when t/stat closed?
You should have a bypass built into the water pump if everything is original. If it has aftermarket or vortec heads it probably doesn't have a bypass. Either way it's good idea to add a bypass hose.
garyd1961 is offline   Reply With Quote
Old 04-15-2019, 11:03 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
The water pump has a bypass built into it on those era vehicles. You could buy a truck with no heater and they worked fine without a bypass hose. I don't know about LS or Vortech, you'd have to check that out. Can you show us a picture of the engine?
~Steven
Simi Valley, CA
