Old 04-17-2019, 01:51 PM   #176
SCOTI
SCOTI's Avatar
Re: TA_C10: Stage 1
Originally Posted by TA_C10 View Post
Pop quiz:
In the picture above showing my new brakes and spring kit? What did I forget to install in this pic?
E-brake hardware.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-17-2019, 10:20 PM   #177
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Originally Posted by SCOTI View Post
E-brake hardware.
Now that I see the pic, its a little hard to see what's missing... I forgot the small SA-Return Spring I had to take the wheel and drum back off after all that work...
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 04-17-2019, 10:31 PM   #178
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Originally Posted by 1971Stepside View Post
I need to order my brake line kit. Which part # (s) did you order? You were happy with fit? I've heard the stainless can be a bear. You are making much better progress than I am. Keep it up.
Yeah man the fit was pretty darn good. There are a few tweaks that you can make but even if you don't it still fits like factory. I would say the only thing I don't like is how the factory set the rear diff clips on the diff cover side instead of on top or behind the diff. So the new kit of course follows that and puts the rear brake line right in front of the cover in front of the top few bolts so if you need to remove your diff cover its a pain in the neck... So if I had to do it all over again I might have bent the lines different back there and installed new clips.
I got the SS lines from LMCTruck. Good quality.
34-5532 DISC CONVERSION LINE KIT-SS 1 $229.95
30-1724 BRAKE LINE CLIP SET-13PC 1REQ 1 $19.95
And I went to rockauto later when I realized I needed those brake line retainers. But here is the LMCTruck part number:
30-1411 RETAINER-REAR AXLE T - You need 3 of them if you didn't keep your old ones. 2 up front, 1 on the rear axle.
Also, if you didn't retain your old brass T's connectors, you will need the one that came off the front above the K member where the lines T up to the master cylinder. The kit comes with all new ones EXCEPT THAT ONE for some weird reason... Oh and this may be because I converted to front DISC, they were drum before. There is a 3/16 T and 1/4 T. The kit comes with the 1/4 T if I remember correctly.
Hope this helps.
EDIT: I just realized the T you need to retain is the the one on the axle in back. The others come in the kit.
"It's only money".
Old 04-17-2019, 10:39 PM   #179
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
And here are those brake line retainers I was talking about. I just installed them the other day. RockAuto.com, came in a pack of 4, pretty cheap too.
This is the junction in the back where it goes from hardline to softline down to the axle. Because of my new C-Notch, I removed the lower portion of the cross member here which of course had the brake line tab on it so I think I am just going to come up with something else, make a new tab of my own, or perhaps just use a clamp.
"It's only money".
Old 04-17-2019, 10:50 PM   #180
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
LS Headers - 1 3/4 long tube Speed Engineering
Little update. I had another thread asking about what to do on this issue. I ended up grinding away some of the motor mount top plate to clear the drivers side header. I was mostly concerned with the nylock nut and it being exposed after grinding back the plate and thinking the heat would melt the nylon in the nut. So I think I am going to get one of those "distorted thread lock nuts" or Fastenal calls them top lock nuts. This should work great.
But anyway, this clearancing worked great and now all I need to do if figure out how to stop the rust on the plate I grinded. They are coated with zinc or whatever and I ground that away.. I don't want to paint them either.... Gotta figure that out.
Header fits great now.
"It's only money".
Old 04-18-2019, 09:13 AM   #181
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: TA_C10: Stage 1
Thanks for the brake line info. I didn't keep anything from when I tore the truck apart (dumb on my part...I'll call that stupid tax). Plan to order these in July per my budget. Thanks again
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 04-18-2019, 09:35 AM   #182
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
I have some pics of my brake lines on page 6 or 7 of thread if you want to see how they route and you can see that rear axle where the line travels in front of the diff cover. Not a huge deal it how it came from factory.
"It's only money".
Old 04-22-2019, 11:45 PM   #183
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - E-Brake Cable Assembly
I took a break from troubleshooting my PCM tonight and got my e-brake cables assembled.
Details on PCM troubleshooting in another thread I started here: http://67-72chevytrucks.com/vboard/s...23#post8510423
My transmission x-member because I flipped it interferes with the normal space the cables occupy but not by much so I just took fuel line and wrapped the supporting cables/rod where they touch the x-member and I think this will work just fine.
And I must say there isn't too much documentation with pics out there on how to assemble this stuff that I found so maybe these pictures will help someone in the future.
"It's only money".
Old 04-25-2019, 04:00 PM   #184
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Updates
Well I pretty well finished my standalone wire harness. I haven't loomed it yet as I think I may have a bad PCM and i'm doing a lot of troubleshooting right now. My bluetooth adapter with Torque app cannot connect to my PCM sucessfully and my fuel pump is not getting 12v for trigger wire at relay via Green connector pin 9. Here is my troubleshooting thread on this: http://67-72chevytrucks.com/vboard/s...49#post8513149
Here is some picture porn for you guys, I know we all love to see pics
Huge mess of wires I removed from harness. I used lt1swap.com to do my harness and program the PCM/ECM.
Although I used lt1swap I decided to upgrade my fuse box to a six fuse/six relay box. Everything else I pretty much did what Brendan did in his videos.
For now I simply washed and cleaned up the truck intake for mockup. I also replaced the knock sensors while I was in there along with new valley pan and intake gaskets. The cam shaft lobes looked pretty good from what I could see. The timing chain seemed to be a bit loose but too hard to really tell from inside the valley pan so I am going to leave it alone for now. Engine upgrades coming in Phase II of this build later down the road.
I plan on making a mount for the PCM and fuse box on the rad support. Looks like I will have plenty of length to make this happen. The wire harness seems to fit pretty good as well after redoing harness. Once I get the PCM issue resolved I will loom the harness and complete it. Dual FAN relays are going in this fuse box. I think the headlight relays I may mount separate.
"It's only money".
Old 04-25-2019, 04:08 PM   #185
Scurry67
Re: TA_C10: Stage 1
Nice job man! You're kicking a** on progress!
Scurry67 is offline   Reply With Quote
Old 04-27-2019, 07:29 PM   #186
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
The LS LIVES!!!
"It's only money".
Old 04-27-2019, 08:58 PM   #187
Kronald_70GMC
Kronald_70GMC's Avatar
Re: TA_C10: Stage 1
Killer man! Sounds awesome!
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 04-27-2019, 10:03 PM   #188
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
It had a vacuum leak on first start. Got that fixed now she purrs like a panther
"It's only money".
Old 04-28-2019, 11:16 PM   #189
cornerstone
cornerstone's Avatar
Re: TA_C10: Stage 1
Congrats!!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-29-2019, 10:13 AM   #190
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Originally Posted by cornerstone View Post
Congrats!!
Thanks guys, big milestone... Now I can loom my harness and finish another step.
The DBW is pretty cool. I hooked up the pedal and played around with it for a minute(it functions with just key on power). It's pretty accurate and works well. Going to be super easy to add cruise control too with the 4 wires I pulled out of the plug.
"It's only money".
Old 04-29-2019, 11:17 AM   #191
1971Stepside
Almost Satisfied
Re: TA_C10: Stage 1
That's a great feeling!! Congrats
Old 04-30-2019, 11:25 AM   #192
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - PAINT!!
It's on like donkey kong
I have never done body work nor have I ever painted a vehicle before. Shoot the closest thing I have come to painting is with my Wagner Flexio 9_something lol.
I bought a starter set of 2 guns from Eastwood, Devilbliss brand. I also went all out and grabbed their starter setup of the DeKups system and I gotta say I had no idea what this really was but now that I have used it twice it's AWESOME! Disposable and reusable stuff. I can see how much time this saves.
I washed the cab with soap and water last Wednesday, it was raining outside so it was perfect time to wash it. Pulled it in the garage and dried it off with my leaf blower and towels. It sat in the garage like that until Sunday when I finally got around to it which was a mistake. It started surface rusting on me. Really it wasn't too bad but I was paranoid so I sanded almost the whole cab. Then I used some self etch from eastwood for rust inhibitor. Should be good
Then I got to spraying. Epoxy primer 1:1 from summit. Sprayed two coats and realized I didn't wipe off all the self etch. So I had so sand a lot of the epoxy back off again as you could see the runs behind the epoxy.
I should have known better but I got in a little bit of a hurry and this is what everyone tells you NOT to do... So from now on I will plan my time appropriately and go slow.
The picture above is how it sits now, all the bad spots sanded back down and re-coated with another layer of primer. This thing isn't going to be perfect, its going to be my DD. But it should look nice when I get done. Next steps are seam sealer, 2k primer, body filler, chit load of sanding, then finally some color.
"It's only money".
Old 04-30-2019, 11:30 AM   #193
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Here is my paint booth From here on out I plan to hang plastic from the ceiling in a box around the center of garage creating some half walls so the paint hits and falls to ground. The 3 fans actually work pretty decent. I crack my inside house door and those fans create a vacuum and sucks everything out the garage door. Just have to make sure the A/C is off because its vacuum inside the house is too much for those 3 fans to overcome.
"It's only money".
Old 04-30-2019, 01:24 PM   #194
cornerstone
Re: TA_C10: Stage 1
:m etal::met al:
YESSSSS! Its a thing of beauty I tell ya... You may have said it before but what color?
Brian
Old 04-30-2019, 06:05 PM   #195
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
:m etal::met al:
Well I am still on the fence on the color. I really wanted to do a gunmetal gray, metallic, single stage, satin. Been looking at the hot rod flatz by TCP Global. Gringo did his blue C10 in that same brand of paint. Supposedly the single stage paints of today are a long lasting paint compared to what they used to be. Even though its metallic, I still think it will be easy enough for me to paint as a newb. I plan to paint the inside of cab, and inside of all the other panels, then assemble the truck and paint it as a whole so it comes out uniform.
"It's only money".
Old 05-01-2019, 10:56 AM   #196
cornerstone
Re: TA_C10: Stage 1
Man we are really on the the same thought train here. That’s my plan too. Ive been planning on getting the same paint gun kit also. You did say you were impressed with the gun didn’t you? I even am considering the TCP global hot rod flatz also, but in a light blue.
Brian
Old 05-01-2019, 12:31 PM   #197
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
I do like the guns, I haven't really used them much just the 1.8 tip for epoxy but so far they seem to be performing really well. The spray pattern seems to be great. They seem to be pretty good quality too. The kit I got came with a pressure gauge that you screw into the gun, its cheap quality as it doesn't seem to be working very well. I have to keep smacking the gauge and working the trigger to make it work.
The Dekups system is really sweet, and it comes with the proper adapters that work with these guns.
My gun kit = https://www.eastwood.com/devilbiss-a...ng-system.html
"It's only money".
Old 05-09-2019, 10:12 PM   #198
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Filling firewall holes
I've been down for a week. Pulled my back out last week so I was put up for a while... Tonight was first night I felt like getting back in there and I started working on the firewall. I realized I couldn't do it with the engine stabbed and the cab back on the frame.
Not much glory yet. Just filled the blower motor hole tonight but its a start to filling a lot of holes
"It's only money".
Old 05-13-2019, 01:15 PM   #199
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Filling firewall holes p2
Got a few more holes filled this weekend. My welding still has a long way to go... After I finished my patch panels aren't exactly flush with the existing firewall so I guess it will have to be filled with body filler.... Good as it's gonna get for now.
I found my bleacher seat pads in the garage and a bucket. Worked out pretty nice working on the firewall
Here you can see my panels didn't turn out exactly flush. Doesn't make me too happy to have to fill this with body filler but whatever, is what it is I guess...
So this is the drivers side. I filled around 8 holes on this side. Are there anymore I can fill that I won't need? I'm running the stand-alone engine harness for the LS. And I was thinking of purchasing the American Autowire wire harness for the truck to use. So I left the e-brake holes and the bulkhead square as well for those. I plan to weld in the holes on the left side here as well after I can identify them if I need them or not. I think the only one I need is the windshield wiper hole.
"It's only money".
Old 05-13-2019, 01:17 PM   #200
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Here is another shot of the holes on left I want to fill. Only one I can think I will need is the windshield wiper hole. Anything else I may need to keep?
"It's only money".
