#526 |
Re: Our "What are we going to do?" 66 Suburban Build
Really changing that up
..WOW that's going to be a beast
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
#527 | |
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
#528 |
We've finished most of what we wanted to do on the chassis...
#529 |
Well, maybe a bit more...repaired a couple body mounts at the rear and then plated all of them.
#530 |
One day...
Im going to have to come check that out. im sure the pics arnt doing much justice.
#531 | |
#532 | |
Hollister, CA.
![]() Join Date: Sep 2006
Scott actually has time to be here !?!? Frame looks good... Not nearly enough Okie Dimple Die holes though.. ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#533 |
A bit on the motor...540 ci w/Carillo rods, Wiseco forged 8.5 to 1 pistons, Kryptonite crank(LA Enterprise) going into a 10.2 tall deck BBC with "Big Brodie" Brodix heads. We're still working on cam choice, but this motor was originally a 900SC from Mercury Racing.
We're pairing it with a 671 Weiand blower and a couple 650 Edelbrocks. The plan is to run around 8-10 lbs boost on pump gas. We may run a couple hundred shot of NOS since we have most of the set-up from the last motor.
#534 | |
Hey John...good to hear from ya! I seriously have had to restrain myself from dimpling crap on this go around...it would never get done! ![]() ![]()
#535 |
We want to be a little obnoxious with this, so we chased down a 4" tall intercooler (gutted) to use as a spacer between blower and intake...make it stick out of the hood more.
![]() The only problem was that it was for a 871. We sectioned/machined/welded the rear of the cooler to fit our shorter (lengthwise) 671 intake. The heads had been painted in their prior life...poorly. We had the heads vatted and then bead blasted them. We wanted to powder coat them clear, but after discussions with Brodix decided not to. Brodix is a couple hundred miles away in Mena, AR...so we ran the heads, lower intake, and spacer to them for a quick refinishing...looks brand new and is the finish we were after.
#536 |
That going to be a beast...how long before you are able to fire this up
#537 |
The first fire/break-in/tune will be on the dyno at the machine shop...I'm hoping in the next month or so.
#538 |
Working on putting the chassis back together...cleaning, painting, and upgrading where we can.
Changed up the wheels and went with a little bigger 31x16.5x15s, also switched over to coil overs on the rear.
#539 |
60-66 Nut
I like it!
![]() What width are those wheels?
#540 |
Thanks Capt., 15x12 on the wheels.
We hung a new gear box on Capt.'s mount...upgrading the steering a bit. Also ran the brake and fuel lines...
#541 |
Scott swung by to get us started on a bit of patching...well, mainly cutting cancer out!
#542 |
We did get one patch in though...
#543 |
Nice work...love the skates makes moving thing around much easier
#544 |
Thanks PE...dollies are mandatory now!
#545 |
Picked up a set of mounts for the block, felt like we needed something stouter than stock...fabbed up the frame side mounts tonight.
Dropped a size on the front tires...275/60R-15 to 255/60R-15 on 8" wheels. We wanted a bit more room for the fenderwell headers at full lock and bump.
#546 |
One day...
Hey i like those.
Firewall came out nice!!! ![]() ![]() |
#547 |
#548 |
Went by the machine shop today...short block is coming together! This piece of the puzzle will move along faster now.
#549 |
We've been gathering other parts up too...
BTE HD T400 w/RMVB, transbrake, 36 element Pro Mod Sprag, Vasco steel input shaft, Vasco steel intermediate shaft...built for north of 1500HP (we won't have quite that, but good insurance.) BTE 11" Race Torque Converter, flash stall around 4K, (spragless w/mechanical diode)...again, good for 1500HP+. JetHot extra high temp coated Schoenfeld fenderwell headers, 2.25 primaries into 4" collectors w/V-band flange. NOS blower injector plate...will keep it around a 200 shot. Kilduff "lightning rod" shifter
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread Last edited by RockTonka; 05-03-2019 at 02:45 AM. |
#550 |
Scott broke away and spent some quality time with us this weekend!
