Old 04-19-2019, 07:47 AM   #1
Rag joint replacement with ujoint shaft, who’s done it?
Just wondering how you like it? What’s the difference in the steering and vibrations felt in the wheel? Noise transfer ?
Old 04-19-2019, 09:38 AM   #2
sweetk30
sweetk30's Avatar
Re: Rag joint replacement with ujoint shaft, who’s done it?
Jeep xj shaft works great .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 04-19-2019, 11:20 PM   #3
Rooster73
this is just my experience , having done countless D shaft installs on streetrods. a ujoint setup offers no [cushion] in the steering, but these are the rigs that have a rack which has bushings at the mounting points. a steerbox mounts solid to the frame, so the rag joint gives the isolation. biggest mistake with a steer shaft with a rack,[hotrods] is when they have to use more than 1 joint they dont time them=binding.
Rooster73 is offline   Reply With Quote
Old 04-20-2019, 04:45 PM   #4
obijuan
In my blazer I used the xj and in my v3500 I used a 2002 chevy Express van shaft which is a two joint system but has a rubber bushing on the shaft that does not transmit any noticable change to the wheel other than the rag joint shortcomings.
If you have a good condition rag joint and slip joint in your OEM shaft you will notice no change.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
obijuan is offline   Reply With Quote
Old 04-22-2019, 12:11 PM   #5
layinrocker65
layinrocker65's Avatar
I’ve upgraded the steering shafts on multiple trucks of mine. It’s a great and cheap upgrade for sure. I did not notice any negative noise or vibrations
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 04-22-2019, 02:03 PM   #6
DieselSJ
Mo betta -
https://www.ebay.com/itm/29299271546...&ul_noapp=true
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 04-22-2019, 02:42 PM   #7
SunSoaked
SunSoaked's Avatar
Holy s**t! $290 for a shaft? Better be gold plated. I've been contemplating this myself. Both junkyards I've visited failed to produce any donors. The Grand Cherokee must be a major POS as both yards were loaded with them. Lol.
My research at Rock Auto lists the Dorman part# 425-284 as fitting the Cherokee (84-94), Wagoneer (84-90) and Commando (86-92). List price is $187.00. That's still a lot of cabbage for an unneeded but wanted upgrade.
SunSoaked is offline   Reply With Quote
Old 04-22-2019, 05:24 PM   #8
obijuan
That borgeson shaft is a huge waste of money. I am all for lavishly pouring money into my truck but that's just unreasonable.
Old 04-24-2019, 06:35 PM   #9
NorCalAnthony
Originally Posted by obijuan View Post
...in my v3500 I used a 2002 chevy Express van shaft which is a two joint system but has a rubber bushing on the shaft that does not transmit any noticable change to the wheel other than the rag joint shortcomings. ...
@obijuan Do you have a part number for that Express shaft by chance? Just tried looking them up and it looks like there's a couple different versions for a 2002 Express... I remember a couple years ago I could find a Dorman XJ shaft for under $100 and they're closer to $200 so another option would be great.
NorCalAnthony is offline   Reply With Quote
Old 04-24-2019, 06:53 PM   #10
Kudzupatch
Kudzupatch's Avatar
Just swapped out steering box with a quick ratio and I was going that route too. But the cost vs benefit was questionable. Couldn't find a used one and refused to pay new prices. So I bought the replacement rag joint with bolts, figured for $15 I would just try it first and then if I hated it I wasn't out a lot of money. A bit of work to grind those rivets out but once I got it back on, ZERO play and glad I didn't spend the money. Works perfect now.
Kudzupatch is offline   Reply With Quote
Old 04-24-2019, 06:58 PM   #11
Looks like their all pricey if new,
https://www.ebay.com/itm/Dorman-Inte...4AAOSwN5hcPmMA
Old 04-24-2019, 07:10 PM   #12
kipps
From what I've heard, it's not a bad run-about. They made a lot of them, and your junkyard probably is still sitting on a pile just before they clean up. Based on a junkyard here a few years ago, you'd think every other vehicle on the road was a dentside ford. Now there's very few left in the yard, but chevy astro's are packed in every corner.
The grand cherokee was said to be the most like a classic pickup of any of the SUV's, and nearly indestructible.
kipps is offline   Reply With Quote
Old 04-25-2019, 11:14 AM   #13
notallthere
I have done it with the XJ shafts on both the C20 and the Chevelle. Steering feels tighter than before even with a brand new rag joint. I found a new one one through Amazon warehouse deals and I think brand new missing bolts cost me 30.00
notallthere is offline   Reply With Quote
Old 04-26-2019, 09:03 AM   #14
v30crewcab
v30crewcab's Avatar
the xj isn't solid, it has a rubber dampner built in. I swap them in every square I got.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-27-2019, 11:23 AM   #15
Axle
Axle's Avatar
Are these shafts, XJ, Express Van, a direct drop in? from column end to steering box?
Axle is offline   Reply With Quote
Old 04-27-2019, 11:34 AM   #16
sweetk30
sweetk30's Avatar
about as much or slight less than borgeson or others . but the price point is way less.
Old 04-27-2019, 02:33 PM   #17
Mathew21
Mathew21's Avatar
https://www.youtube.com/watch?v=H9C4RdvjPNQ
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 04-28-2019, 04:55 PM   #18
Axle
Axle's Avatar
Thanks. Now I got one more thing to keep an eye out for in the wreckin' yards.
Alex.
Old 07-31-2019, 11:21 PM   #19
1774btcrew
1774btcrew's Avatar
Any info on the express van shaft? It may be an easier to find option for me than the jeep
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 08-01-2019, 08:48 PM   #20
MikeB
MikeB's Avatar
I didn't read all the above comments, but I can tell you from experience, if you have power steering, you will get a whining pump noise and vibration up through the u-joint into the interior.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-01-2019, 09:01 PM   #21
1774btcrew
1774btcrew's Avatar
I realized I had a spare XJ shaft and just posted it in the classifeds
Old 08-01-2019, 11:56 PM   #22
SunSoaked
SunSoaked's Avatar
After months of research and doing the swap myself, this is the first I've ever heard about this issue. Mine performs exceptionally well.
Old 08-02-2019, 09:14 AM   #23
MikeB
MikeB's Avatar
While I can't speak to the 69-87 truck steering boxes, I did have the noise & vibration issue in a 55 Chevy car with a GM "605" box that the PO had installed (a popular way to add power steering back in the 1990s). As suggested on 55-57 Chevy forums, replacing the u-joint with a rag joint totally silenced the noise.
However, your post has me thinking about replacing my 82 C10's very old rag joint with a new one from Borgeson (not some cheap import) or maybe even their ball bearing u-joint or vibration-reducing u-joint. Think I'll call them to ask for their recommendation. Super good company that still makes their stuff in the USA!
Mike
Old 08-02-2019, 12:06 PM   #24
drmatera
drmatera's Avatar
I'm in the middle of that upgrade now on my 81 K10. And there is a rubber isolator up at the column end that should prevent vibration coming up thru the steering wheel. This is a factory Jeep part and I doubt they wanted vibrations.
drmatera is offline   Reply With Quote
Old 08-05-2019, 03:52 PM   #25
SCOTI
SCOTI's Avatar
I just finished swapping in a Jeep/Cherokee XJ u-joint shaft in place of my 2wd duallys rag-joint shaft. I purchased a new part for the swap from Summit Racing (Crown Automotive Steering Shafts; p/n 4713943) for $112 out the door.
So far, I have only logged a few miles on the crappy asphalt patched roads around my area but I didn't notice much if any difference in vibration vs. the rag joint set-up. There is an anti-vibration joint set-up @ the column end so it's not 100% solid. Steering feel is tighter (as anticipated) & I definitely feel better on a safety level.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
