05-30-2004, 10:38 PM | #1 |
yeller
400 Id
I know it has been discussed before, but how can you ID a 400 from the outside? Arent there external weights on the flexplate or balancer? Something about the number of freeze plugs?
Thanks.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
05-30-2004, 11:06 PM | #2 |
three freeze plugs instead of two . and a differnt balancer
05-31-2004, 12:57 AM | #3 |
Genuine Chevrolet
I'll go along with the external balancing on the flex plate but, my 77 Blazer Chalet has the original 400 and has only two freeze plugs.
George 82 Silverado LWB 4x4 350 SM465 NP208 77 Chevrolet Blazer Chalet 400 TH350 NP203 |
05-31-2004, 01:37 AM | #4 |
california fill
the freeze plug thing isnt 100% accurate all the time, but its been a while since I figured out the discrepency, so use caution...
but the balancer and flexplate are both weighted and are dead give away's... A chevy by the numbers sort of book (or a printout from mortec.com) would be an excellent identification tool also. If the heads are off, look for the siamesed cylinders with the steam holes between bores.. pc |
05-31-2004, 03:22 AM | #5 |
if its a small block with 3 freeze plugs each side of the block then it is definatly a 400. however, just because it only has 2 dosen't mean its not a 400, because there were some.
on the balancer, it is actualy a blancer, not a damper, so there is a section cut out of the outer diameter of the balancer to keep the assembly in balance. and there is a counter weight on the flexplate as well. then there is always the casting numbers that you can look up
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
