Old 04-20-2019, 11:49 AM   #1
jadedbird
jadedbird's Avatar
Windstar Electic fans, do they have to be wired for variable speeds
So its a 6.0 inor block and a 6l80e transmission.
I wanted to go with a 99-03 cherokee fan (2661-0016) with a sbc fan shroud but it looks like too tight of a fit.
So I'm looking at 95-03 windstar fans (FO3115111).
Can they be wired to run one speed? Or does it have to be programmes to run variable speeds?
I would just like to stagger their activation temps and have the small fan run for 10 minute delay after shutting down the truck.
I was planning on using a universal summit fan electric fan thermostat kit, but it looks like you have have your on programmed to run them
jadedbird is offline   Reply With Quote
Old 04-20-2019, 04:52 PM   #2
beadblaster
beadblaster's Avatar
Re: Windstar Electic fans, do they have to be wired for variable speeds
I run a variable speed mark v11 fan on only a high speed circut. There should be three wires coming from the fan ,aground,low spped and a high speed wire. I only used the ground and high speed wire. If you want a great fan controller get the dakota digital pwm controller.
beadblaster is offline   Reply With Quote
Old 04-20-2019, 05:56 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Windstar Electic fans, do they have to be wired for variable speeds
Here is a link I have on my 2 speed fan in the truck and Impala. Both are wired with the micro switches to turn the fans off at highway speed.
http://67-72chevytrucks.com/vboard/s...d.php?t=738555
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
