04-23-2019, 08:43 AM | #1 |
250 Carb, Intake and Exhaust
I am looking for suggestions on exhaust, intake and carb for my 69 stepside. The engine is a stock rebuild with a stock style cam and the cylinders were bored during the rebuild. I am going with HEI or Petronix. It has power brakes, power steering and eventually A/C, and I am keeping the stock 3 on the tree. I have a Muncie 3 spd overdrive that I may put in later. I live in SW Missouri where it doesn't get too cold for too long. I wouldn't drive it during the winter much anyway so not too concerned with the intake heating. I am more interested in reliability and driveability. I wouldn't mind a bit more power if didn't come with any issues.
Sooo, my question is should I stick to the stock stuff or throw on some aftermarket parts? Anyone have experience taking a more or less stock 250 and adding the goodies? Does it really make a difference on a driver with an otherwise stock engine? Will I suffer from tuning, idle or driveability issues? Last edited by bubbasimms; 04-23-2019 at 08:49 AM. Reason: adding pictures |
04-23-2019, 08:52 AM | #2 |
Re: 250 Carb, Intake and Exhaust
Check out Clifford performance. He has some nice stuff
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
04-23-2019, 09:28 AM | #3 |
I had a worn out 250 inline in my 68 impala in highschool. It was a boat. the biggest performance increase I ever made to it and just overall made it 10 times better was fitting a nv3500 5 spd to the back of it from an s10. The closer gears and overdrive made the car a lot better at accelerating and mpg. Like a ton. It would burn rubber through 1st and chirp 2nd.
But I definitely understand keeping the original gearbox. Cool truck! |
04-24-2019, 01:03 PM | #4 |
04-24-2019, 09:46 PM | #5 |
Thanks for the links and the input thus far. A decent intake, some headers and a new carb will perk up an old small block a noticeable amount. My question is do these high dollar parts make any significant difference when added to a stock 250?
04-25-2019, 03:12 PM | #6 |
They actually do make a difference. I once put just headers on a 250 and could tell the difference. I've read that with headers, cam, intake, and carb upgrade they can make for a fun engine to play around in. and still upset a few sbc owners.
04-25-2019, 03:44 PM | #7 |
This is what's going on mine. Also in the middle of doing a T5 swap. Will be going EFI with it as well. Going to be an all weekend cruiser, with AC to boot.
That's Clifford stuff in the photo btw.
1972 C30 Grain Hauler, 350/400 1967 1500 GMC Stepside SWB, In Transformation Process 1967 RS/SS Camaro 350/TKO600 |
04-25-2019, 05:39 PM | #8 |
What's your plan for the efi?
04-25-2019, 08:12 PM | #9 |
I’ve been running a FiTech in my Camaro for the last 3years and love it. Just trying to decide which version to run on my 250. Leaning towards a 400 right now.
04-26-2019, 02:01 AM | #10 |
In my '68 C/10 Stepside I run a 292 L6 bored .030 over, with Badger pistons, Crane 260H cam, oversize 1.84'' Intake valves, inside. Outside I have a GM HEI remote coil type [ask for 1975 MY 292 cap and coil], Edelbrock 1404 500 CFM 4 bbl carb, on an Offy intake and Clifford long tube headers. I drive a Truck, so it isn't lowered or modified off stock stance. If you have any suspension mods, you may not want long tube headers. Langdons cast iron headers may work in that case. They are a ''Late Chevy L6'' iteration of the old stovebolt Fenton iron headers that the 235/261 guys loved. Tom Lowe at www.12bolt.com sells them now, as Tom Langdon retired.
Another L6-specific reference is www.inlinersinternational.org It's another forum like ours that's all about inline engines [only]. I used to be a member. I was invited to a recent meeting of the AZ chapter, down in PHX, but they were mostly Ford guys. Go figure. Anyway, very knowledgeable people about the Straight 6 engines and willing to share their expertise.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 04-26-2019 at 03:05 PM. |
04-26-2019, 04:47 PM | #11 |
I run Clifford intake and split manifold headers, with a Holley 390 4 barrel carburetor. Yes, It wakes it up substantially. Love my setup:
Steve My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory 1971 C10 Inline 6 250 700R4 "Marlene" 1934 Chevrolet Master Sedan 350 700R4 "Iris" 1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose" 2019 Honda Ridgeline |
04-26-2019, 08:26 PM | #12 |
That's a sweet setup....where did you go for the accessory brackets?
04-27-2019, 06:13 PM | #13 |
The accessory brackets are from ECI Hot Rod Brakes. Nicest I've found.
http://www.ecihotrodbrakes.com/ Also run a valve cover from 12 bolt.com Better link
Steve My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory 1971 C10 Inline 6 250 700R4 "Marlene" 1934 Chevrolet Master Sedan 350 700R4 "Iris" 1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose" 2019 Honda Ridgeline Last edited by cruisinthe34; 04-29-2019 at 07:18 AM. |
04-27-2019, 06:33 PM | #14 |
Bubba, what a beautiful truck brother.
04-28-2019, 10:06 PM | #15 |
Those brackets are great...think I'm gonna get those instead of the Davis speed setup. Ronzo you talking to me?
