Old 04-23-2019, 02:26 PM   #1
Ad Cam
Ad Cam's Avatar
Best way to temporarily fill holes in roof?
Previous owner had one of those sun visor things screwed into the roof of my truck (26 screws/holes to be exact.) Holes look like 3/16" or so. I want to seal them up so no moisture gets inside if I get caught in the rain. Any thoughts on how to temporarily close them? JB Weld? Silicone? Chewing gum? Silly putty? Any ideas are welcome. I was thinking of some small screws and putting silicone over them, but not sure at this point. Thanks!
Ad Cam is offline   Reply With Quote
Old 04-23-2019, 02:34 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Best way to temporarily fill holes in roof?
my truck came from a fire dept so it had plenty of holes in the roof from antennas and lights....all that had been removed and had gobs of silicone in the holes....i would think screws,washers,and silicone would be a better temp fix
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-23-2019, 02:39 PM   #3
notsolo
notsolo's Avatar
Not a fan of silicone caulk, I would use polyurethane caulk.
notsolo is offline   Reply With Quote
Old 04-23-2019, 05:20 PM   #4
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up Re: Best way to temporarily fill holes in roof?
I'd go to your local auto paint supply shop and get some seam sealer it's made for sealing out moisture.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 04-23-2019, 08:01 PM   #5
jocko
jocko's Avatar
Since you said temporary - I'd go with a screw, a rubber washer under a same-size metal washer, and a very small bit of caulk on both sides of the rubber washer and some under the screw head. Should do until you get around to a metal repair if that's what you mean by temporary.
Old 04-24-2019, 12:39 AM   #6
Ziegelsteinfaust
In hvac installs they use a very gluey aluminum tape, and it will last a couple.months.
I do service so I am not up on the install terms
Ziegelsteinfaust is offline   Reply With Quote
Old 04-24-2019, 11:00 AM   #7
SunSoaked
SunSoaked's Avatar
26 holes! That's crazy. I recently installed a Lund Moon Visor and it only took eight 1/4" screws.
SunSoaked is offline   Reply With Quote
Old 04-24-2019, 01:48 PM   #8
abig84
abig84's Avatar
Mine had a bunch of little holes too as it was a old brush truck, i just put in regular rtv silicone the stuff you use for doing intake/oil pan gaskets. That was over 10 years ago and its still holding. I always figured silicone would be the easiest to just pick out if you ever wanted to
abig84 is offline   Reply With Quote
