Old 04-27-2019, 07:02 PM   #1
Patience
1959 Apache 38 Dually Brakes Question
Hello, so I'm taking apart the front end of my Apache 38. I've searched for how to convert to disc brakes, but haven't found anything that can work with the Dually set up.
Has anyone else ran into this?
Also, the dually wheel "Extender" that bolts to the drum won't come off. Is it pressed in at the back where the rear bearing rides? Or do I just have some rusty a$$ stuff that can be negotiated loose with force? Has anyone converted from the ball bearings to tapered rollers?
I've attached pics. Thanks in advance for any advice/tips/help.
-Sam
Name:  Front Hub On.jpg
Name:  Back Side Front Drum.jpg
-1959 Chevrolet 261 Apache 38 - 1 Ton Dually
Patience is offline   Reply With Quote
Old 04-27-2019, 10:02 PM   #2
farmall
farmall's Avatar
Re: 1959 Apache 38 Dually Brakes Question
I need to convert to rollers as well. Part numbers would be great. All I can find is...http://www.classictruck.com/product/...Wheel_Bearings
The drum is for a single wheel so why would the dually adapter not bolt up to the disk?
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 04-28-2019, 11:46 AM   #3
Patience
Farmall -
The inside set of stud bolts are set into the drum, so if I delete the drum, then I'm not seeing where I'd be able to bolt that extender piece for the dually front wheel.
Sweet deal on the bearings. I'll have to shoot them an email to make sure they're right. I've found lots of parts for the 1/2 tons, not a whole lot more on the 1-tons.
Thanks!
Old 04-28-2019, 02:11 PM   #4
farmall
farmall's Avatar
There was a guy in Houston making kits. He passed away recently and nobody picked up the pieces. I cant remember the name. There may still be pics or video on the net. The name might have been xxxxx rd. or something like that.
Old 04-28-2019, 02:37 PM   #5
farmall
farmall's Avatar
It was Hollister Rd Co.
Old 04-30-2019, 04:48 PM   #6
jfnar
You might find some useful info here:
https://www.stovebolt.com/ubbthreads...ml#Post1285319
Also: https://www.ebay.com/itm/1955-1956-1...BSzy2r&vxp=mtr
jfnar is offline   Reply With Quote
Old 05-05-2019, 08:46 PM   #7
Trekster
Trekster's Avatar
The extender is one piece. It doesn't come off. Push the studs out that hold the drum on and bolt a disc on like Farmall's picture shows.
Trekster is offline   Reply With Quote
