Old 05-03-2019, 03:59 PM   #1
WhiteCST
WhiteCST's Avatar
12 Bolt Pinion Seal Help
Alright guys I need some help. I have a 12 bolt out of my 68 C10. 3.73 gear ratio and I believe a 9.75 ring gear. I can’t find the proper pinion seal for this thing. The old seal didn’t have a part number so I’m out of luck there as well. I know for certain it’s not an 8460 or a 6808. Both of those seals are too small and will easily just sit in place. Anyone have any insight on this?
1953 Kaiser Manhattan “Sled”
1968 C10 CST LWB
1991 Trans Am GTA “White Nasty”
2006 Dodge Charger RT
Built TH400 for Sale
WhiteCST is offline   Reply With Quote
Old 05-03-2019, 07:31 PM   #2
Mike C
Mike C's Avatar
Re: 12 Bolt Pinion Seal Help
8.75" if it is a 12 bolt truck. With GM numbers on the ring gear, that would be my guess.
I have never had a problem just going to the parts store and asking for a seal for the vehicle. But the date on that Ring gear, if it is 1 of 67 would not have been found in a '68. Have the parts guy look up the seal for a '67 12 bolt. I would not have thought them to be different, but you never know.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-03-2019, 09:11 PM   #3
gmc684x4
The truck 12-bolt uses a smaller inner pinion-bearing (1.438 inches versus 1.675 inches)
Could the parts guy given you a seal for a car 12 Bolt ?
On another thread on here the fella stated he got a seal from chevy that fit better then the Nappa seal
https://www.chevyhardcore.com/tech-s...rearend-guide/
gmc684x4 is offline   Reply With Quote
Old 05-07-2019, 02:34 AM   #4
WhiteCST
WhiteCST's Avatar
Well after quite a bit of searching I determined an 8622 National seal fit like a glove. Not sure what application it’s for, but if you find yourself in the same situation as me give 8622 a shot.
1968 C10 CST LWB
Old 05-07-2019, 02:44 AM   #5
WhiteCST
WhiteCST's Avatar
I’ve also determined that the same seal is used on the front diff for 80’s K series. However, I am still unsure of what 12 bolt I have
1968 C10 CST LWB
Old 05-07-2019, 04:42 PM   #6
StingRay
StingRay's Avatar
The truck 12 bolt is 8.75". They were used from the 60's to the 80's and there are literally millions of them out there. The parts should not be hard to find.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
