Old 04-27-2019, 02:27 AM   #26
mongocanfly
mongocanfly's Avatar
Re: 81 k10 12 bolt differential rebuild
And one other thing...do yourself a favor and get a crush sleeve eliminator kit if you havnt already....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-05-2019, 07:14 PM   #27
juiceboxhero
juiceboxhero's Avatar
I spent the extra money. And got the yukon crushless kit. The master rebuild kit came with 2 crush sleeves. I tried my hardest to get one of then to set and crush, no matter how hard I tried my impact would not crush it, enough even having a pipe wrench on it and always left play front to rear. So i used the sleeve as a base for the crushless. Ended up using the 7 ish thousand shim only. Cutting it close.
The pinion patter is on the acceptable side but is slightly close. Tried withouta shim and somehow it was to far out. Thankfully i found and old and i mean old micrometer. Shimming the carrier was the easiest part with the assortment from yukon.
Almost complete. Autozone screwed me and ordered the wrong axle seals. They ordered the front.
juiceboxhero is offline   Reply With Quote
Old 05-05-2019, 08:36 PM   #28
sweetk30
sweetk30's Avatar
almost all autozone bearings and seals now are super cheep CRAP JUNK .
last time i needed a dana 60 carrier bearing they didnt have timken anymore and there store brand was so cheep the bearing didnt even have part #'s on it anywere or even a name .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-05-2019, 08:48 PM   #29
juiceboxhero
Agreed.
Thankfully o'Reillys had them in town for 3.99 made in the usa. Surprised me.
Old 05-06-2019, 09:42 PM   #30
juiceboxhero
Completed.
It was frustrating at first, but after installing then disassembling it multiple times. I am comfortable with it now. The most frustrating part was the crushless and trying the crush sleeve first.
Thank you for all the help.
Now i will have to get the proper gear for the np208 speedometer. Ill just be using my phone as a speedo for now. Ulysses speedometer has a cool program where it'll reflect off the windshield.
Old 05-10-2019, 01:13 AM   #31
layinrocker65
layinrocker65's Avatar
I’m going to be doing the same gear change here soon. Anything you would change now that you’ve done it other than not using the crush sleeve?
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 05-10-2019, 09:53 AM   #32
juiceboxhero
Overdrive. Haha, this truck screams at 70.
A good vise would've helped me installing the ring gear. I had to hold it while torquing the bolts.
I didn't have the option to completely remove the axle from the rear which made it a bit difficult but definitely doable.
I have been pretty happy with the moog non greasable u joints.
Old 05-10-2019, 02:39 PM   #33
layinrocker65
Thanks. I already have a 4L80e. The 3.08 gears are just way too tall for my truck.
‘53 GMC COE stock
12bolt, differential, k10
