05-11-2019, 02:11 PM | #1 |
1971 - best OEM style full tie rod assembly?
Just getting everyone's take before I go up to O'Reilly's or somewhere and start laying down money...
We want to replace the tie rods (all 3 parts), and the pitman arms. What are the best/most reliable OEM-style, put-it-in-and-go ones to get. ...Also, I know the tie rods changed every couple years, so I don't want to grab the wrong part because the counter guy is a pimply 12-year-old and knows nothing (or less than me, anyway. I know, at least, next-to-nothing. ). Moog seems popular, but it appears to be a bit different than the originals? Thoughts? Suggestions? |
05-11-2019, 02:16 PM | #2 |
Re: 1971 - best OEM style full tie rod assembly?
I replaced my entire front steering and suspension with moog all parts matched up fine. I found the best prices on rockauto
Doug 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US |
05-11-2019, 02:31 PM | #3 |
I'm assuming it was something like the "MOOG ES415RL" part number on this page?
https://www.rockauto.com/en/catalog/...e+rod+end,7428 |
05-11-2019, 02:43 PM | #4 |
Side note... on a whim, I called LMC just now, to see what brand theirs are.
The brand is 3D Carbon. And I don't know anything about that company, but they did say "made in US," if that matters to anyone. ...Something tells me that's just a detail about manufacture.. Not a brand. Oh well, I tried. |
05-11-2019, 02:43 PM | #5 | |
05-11-2019, 03:20 PM | #6 |
Moog from Rockauto . If your going to replace it , Replace ALL of it , Upper and lower control arm shafts , upper and lower ball joints ,inner and outer tie rod ends ,idler arm , 9/16 u bolts . Have it aligned and your done .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
05-16-2019, 09:38 AM | #7 |
Do you have the part numbers for all the Moog stuff? Everything up front on my truck needs replacing.
05-16-2019, 10:10 AM | #8 |
I have all the part #s for a 67 . You'll need to use everything for your model , I used CCP 2 1/2" drop spindles and disc rotors/bearing kit ordered thru Summit with free shipping . Disc splash shield off ebay and bearing cap/cover from autozone .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 05-16-2019 at 10:15 AM. |
05-16-2019, 10:11 AM | #9 |
Look it up on RockAuto. Going to depend if you are 10/20, and C/K
Agree to do it all at once. If you decide to use AC Delco, be aware they have 2 product lines now. Advantage and Professional. Advantage is cheap chinese junk. Professional is the real AC Delco parts.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
05-16-2019, 10:17 AM | #10 | |
05-16-2019, 10:48 PM | #11 |
moog has two lines as well, if it doesnt have problem solver stamped on it, its their cheaper line.
Tags |
pitman arms, tie rods |
