Old 05-12-2019, 01:20 PM   #1
Furno68C20
Steering Column/wheel question
I want to go back to the 3 spoke steering wheel and horn button. The problem is I don't know if my column will work with the original wheel. attached are pictures of the wheel/button, and column with tilt.
I believe the column isn't original since it has tilt and the truck is a 68. Can a later column with a earlier wheel/horn button like I have?
Need to know what Steering wheel kit I will need. Can anyone help on this issue?
Thank you
Furno68C20 is offline   Reply With Quote
Old 05-12-2019, 02:43 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Steering Column/wheel question
It should work just fine as long as it's a Chevy tilt wheel column. You will need the horn stuff for the 67 model to fit inside the wheel.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
